While browsing this site: http://www.high-endaudio.com/RC-SpkrCab.html I noticed interesting comment on Polk speaker cables. Yesterday, I met another local audiophile who had those cables and he indeed confirmed that they are one of the best.
Any idea about availability of those, as it seems like they are very rare now.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2 |
If these were the ones from late '70s/early '80s, they were total amp-killers. You can get the same result by hanging a 0.1uF cap across some zip cord- or, even better, orange Home Despot wire
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
If you really want a low inductance solution with less capacitance than the Polk wire, try 4 parallel runs of RG-8. Connect all the shields together, all the cores together, and you have 0.018 uH/ft at 120 pF/foot. For an 8 foot cable that's 0.144 uH and 0.001 uF. Resistance is truly negligeable because each RG-8 is about 12 gauge, so the 4 combined are close to 6 gauge.
The only problem is you'll find the wire inside the cabinet presents an order of magnitude more series impedance than the lead-in... Cheers, Francois. |
#4 | |
#5 | |
Of course, for *really* good results, I'd eschew binding posts, klugy things that they are, go with UHF connectors on amp and speaker, and run coax on the internal wiring as well. Francois. |
#6 |
You could drop by:
http://clubpolk.polkaudio.com/forum/ Some of the members have those cables. They even show up in the flea market on occasion. At the very least, they'd be happy to share their opinions of them. regards Dave |
#7 |
DSP_Geek,
so for your recommended amp -> speaker connections you would use one coaxial cable for both the positive and negative connections or perhaps a dual twisted crossconnected design (like Jon Risch's). By UHF connections do u mean BNC plugs, or maybe F or H type connectors?. I'm in the process of making a chassis for my recently completed 3875 gainclone and will be making my own speakers, thus I am free to implement any connections I see fit. Peter, Sorry for diverting your thread topic. Kudos to yourself and Brian for developing such great kit. I was surprised how quickly an amp could be made, turning it on the first time sure was nerve racking, but oh what sweet music it makes. I'm listening to right now as I type, surprising how much the sound is changing as it "burns in". The only problem is I think you might have started another addiction for me On the topic of the cables, I was wondering if they are still in production today, I travel yearly to Japan and my inlaws live there. If the name of the Japanese manufacturer could be found, I could attempt to hunt it down. |
#8 |
frugal-phile(tm)
Cobra cable was one of the very 1st exotic speaker cables. We sold them (for a while) in the late 70s. They were indeed amp killers -- one of the reasons we quit selling them.
I recently flogged off all 4 sets that i had. They used 2 colors of enameled wire braided over a plastic core at approximatly 90 degrees with a sheath of clear plastic. Besides the capacitance issue, there was a tendency for the enamel to scratch & short-circuit. They were also a pain to re-terminate. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
Had a pair myself, the Bryston 2B never complained.
| Carlsbro Cobra 90BG resistor help | SM2GXN | Instruments and Amps | 3 | 28th June 2011 07:40 PM |
| polk, celestion, vifa raw speaker drivers | ke4mcl | Swap Meet | 5 | 7th January 2010 04:22 AM |
| how much did you pay for speaker cables | peteS | Multi-Way | 43 | 12th March 2006 01:22 PM |
| cables for diy amps, preamps, and speaker cables ... | paulspencer | Solid State | 5 | 3rd August 2004 07:14 AM |
| speaker cables | dave k | Multi-Way | 7 | 25th May 2003 08:51 PM |
| Page generated in 0.12418 seconds (81.21% PHP - 18.79% MySQL) with 11 queries |
