In flipping through a book Simplified Practical Filter Design, Irving M Gotlieb, I came across a passage that confuses me. Actually more than one but lets try this.
That for a second order filter the resonance freq is 1/(2*pi*rt(LC)) this looks fine. But then he goes on to say that cut off frequency is not the same for high and low pass networks just by flipping around the reactive devices all other things constant. What? Next he goes on to explain further that for high pass fc = 1/(4*pi*rt(LC)) and for lowpass fc + 1/(pi*rt(LC)) Does this make sense to any one? Maybe I am lost but the charcteristic equation for second order filters does not show a 4 fold difference -- in fact no difference. Do I need to through this book away? Any thoughts cheers |
#2 |
I don't have any reference books to hand but your 1st equation seems right if rt = sqrt. The versions without and with 4 as a factor seem wrong and I cannot understand his idea that lopass & hipass should be calculated differently. regards AndrewT. |
#3 |
Did it Himself
Depending on filter Q, the crossover point is not always at -3dB for each filter.
The equation you give does not have a 4 times difference between the two frequencies as the 4 is on the bottom. When was the book originally published?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 | ||
My thought exactly Quote:
Doesn't matter top or bottom -- multiply or divide by 4. Book was published in 1990 cheers |
| low frequency, high pass filter | memphissound | Multi-Way | 6 | 19th March 2007 09:11 AM |
| To Low Pass Or Not To Lowpass...That Is The Question | CarlosT | Full Range | 2 | 18th December 2006 11:45 AM |
| Active lowpass filter + high rails | Firebug24k | Solid State | 4 | 19th September 2004 07:47 PM |
| How to add a high / lowpass to an IGC / GC? | Cradle22 | Chip Amps | 27 | 8th December 2003 09:31 AM |
| how to make high/lowpass filter in series connection??? | limking | Multi-Way | 22 | 24th July 2001 03:50 PM |
| Page generated in 0.07811 seconds (72.41% PHP - 27.59% MySQL) with 10 queries |
