Old 31st January 2005, 09:37 PM   #1
Speakerholic
Cal Weldon's Avatar
Default Looking for a photo of the front of the Selenium 15" Coax
I can't seem to find one anywhere on the net. Just the back and side shots are available.
Appreciate it if you have one, I'd like to see what they did with the tweeter.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st January 2005, 11:42 PM   #2
rcavictim's Avatar
I have the 12CO1P Selenium coaxials and can post a picture for you. That is exactly the same as the 15". All you see is a sonically transparent dustcap. The HF horn is a conical hiding just behind this cap. The cap moves with the woofer cone. It is a clever (and IMO better) way to keep out dust. The other method was to use a felt washer between the moving woofer cone and the stationary horn.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 1st February 2005, 12:13 AM   #3
rcavictim's Avatar
Here is a picture of the front of the 12 coaxial. I could not get the camera to image behind the dustcap but with a strong flashlight held up against the dustcap you can just see the horn and throat immediately behind it. The horn mouth looks to be about 2-1/2" diameter at the mouth. I think the crossover is at about 2K on these with the factory crossover.
Old 1st February 2005, 12:18 AM   #4
GM is offline GM  United States
GM's Avatar
The spec sheet has a 3/4 front view, but like RCAvictim noted, all you see is a dustcap that's supposedly acoustically transparent.
http://www.partsexpress.com/pdf/264-392.pdf
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st February 2005, 02:33 AM   #5
Here's a picture of a 12CX with the dustcap removed. You can also see where I ripped a hole in the cone The white dot in the middle is the tip of the tweeter's phase plug reflecting the flash.
I thought the treble sounded a little cleaner without the dustcap.
Old 1st February 2005, 04:19 AM   #6
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
The metal horn on the 15's stick out further than shown in the pics for the 12's. That dust cap is NOT acoutically transparent. It attentuates the HF significantly. Please let me know if you figure out some easy mods to smooth that tweeter. I'll probably end up mounting another tweeter right on the end of that metal horn since it is quite solid on the 15's. Sorry I can't upload any pics for you.
Everyone has a photographic memory. It's just that most are out of film.
Old 1st February 2005, 04:01 PM   #7
GM's Avatar
Hence my 'supposedly' caveat. When asked, for HIFI apps I always recommend removing these and/or the bug screens in compression drivers.
Not familiar with this one, but for HIFI apps, damping with Dammar or similar smoothes any metal or composite diaphragm I've tried it on. For really severe modes, silicon caulk has worked well for me.
GM
Old 1st February 2005, 07:48 PM   #8
Speakerholic
Cal Weldon's Avatar
Thanks to all who answered.
I kind of figured it must be a conical horn in behind there.
Cal
Old 1st February 2005, 11:51 PM   #9
JohnG is offline JohnG  United States
Look here for an extensive report on the HE12.1. One of the pictures is of a 12" Selenium coax with the dust cap removed. It shows a horn that protrudes well past the attachment of the voice coil to the cone.
http://www.cognitivevent.com/av_he12.html
John
FS: Two used Selenium 10PW3-SLF 10" Drivers WillD Swap Meet 0 2nd November 2008 11:11 PM
Tang Band / Selenium project. The "FK" Pano Multi-Way 12 24th May 2008 01:37 AM
Selenium WPU1509-SLF 15" Pro Sound Driver gpsmithii Swap Meet 0 29th December 2007 01:00 PM
selenium coax speaker question darth_sanchez Multi-Way 113 25th March 2005 02:27 AM
Anyone used Selenium 15" Woofers? Cal Weldon Multi-Way 0 17th January 2004 12:12 AM
Page generated in 0.09720 seconds (77.60% PHP - 22.40% MySQL) with 11 queries
