i'm thinking of adding a fostex t90a supertweeter (8 ohm) to a pair of supravoxes (4 ohm) on open baffles.
if i connect the supertweeter in parallel what is the system impedance going to be? i found a calculator that says 2 2/3. this is low for my amps that have 4 ohm taps. any help will be (as usual) appreciated. |
#2 |
The supertweeter needs a higpass filter so the impedance will not change for the woofers. The impedance will be 4 Ohm (nominal) in the low/mid frequencies covered by the woofers and then, in the supertweeter region, the impedance will be 8 Ohm (nominal).
Impedance is not well represented by a single number, it is frequency dependant. F |
| 2xBG20 w/ supertweeter | technofreak | Multi-Way | 0 | 12th December 2006 08:07 PM |
| help me choose a supertweeter | SPU_SPU | Full Range | 3 | 3rd July 2006 06:32 PM |
| supertweeter help... | one1speed | Full Range | 12 | 30th March 2006 09:12 PM |
| Supertweeter CTC distances | Dumbass | Multi-Way | 0 | 28th March 2006 09:50 PM |
| Good supertweeter? | morbo | Multi-Way | 1 | 25th September 2004 07:07 AM |
| Page generated in 0.08757 seconds (68.27% PHP - 31.73% MySQL) with 10 queries |
