Old 30th January 2005, 03:16 AM   #1
Default Dayton PT2B-8 thoughts?
Throwing some more speaker projects around in my head, mainly another set of line arrays, and was wondering what you guys thought about these Dayton planars? I see they've been redesigned a bit; better cosmetics, higher sensitivity and I think I remember reading that it can be crossed lower. I've almost got my set of line arrays done that utilize 10 Dayton RS5 per side with a single Fountek JP-2.0 ribbon, but after seeing the new Dayton planars I kind of want to build a TRUE set of arrays. I could throw some buyout 4.5" Vifas that I have in my current arrays and the Founteks and sell them to my brother for what I have in them, then design and build a set of arrays using 12 Dayton RS5s and 9 Dayton PT2-B per side. I already have the RS5s because I bought 20 for the speakers and an extra 6 just in case, so I'll use 24 of the 26.
I designed these line arrays I'm working on now after Dr. Griffin's Needles array that I heard at the Dayton Ohio show this year. For a calculated seating distance (which is where I do most of my listening) these single ribbon line arrays can have their crossovers designed so they are utilized for that seating position. Do you guys think I'd be better off finishing these arrays with the RS5s and Founteks or go ahead and build a true array?
Am I crazy? Explain!
Thanks!
EDIT:
On a side note, how do you guys feel these compare to other tweeters for doing a bookshelf speaker, or possibly and MTM floorstander?
Old 31st January 2005, 05:29 PM   #2
I vote:
build the big array using 8 PT2's per side and how many
midwoofers you can fit. /hehe
The PT2 type of planar shines in line arrays but it wouldn't
be my first tweeter choice for a simpler design, ie .. I'd rather
use a good dome tweeter instead.
Old 31st January 2005, 09:28 PM   #3
Speakerholic
Cal Weldon's Avatar
mazeroth,
I too am interested in others thoughts on those as I plan to use that tweeter crossed first order at 10K to take over from the little Monarch/Coral 4"alnico drivers I have. I hope you get good responses.
Better than what thylantyr said about using a single one anyway. The big meany would rather use a dome.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st February 2005, 04:29 AM   #4
dtaylo3 is offline dtaylo3  United States
Default Line Array with Dayton
Check with Rick Craig at www.selahaudio.com and see his posts at Madisound and Parts Express. He is in the process of building a line array with the 5 inch PE RS drivers and I think Fountek ribbons, but he has lots of experience with the PE Dayton ribbons.
By the way, I say go with the full array of 8 ribbons vs. just one.
Dayton PT2B-8 good tweeter for line array use? thadman Multi-Way 3 13th September 2011 04:51 AM
Vifa Xt25 + P13wh + Dayton RS180-8 your thoughts? K-amps Multi-Way 14 25th July 2008 05:51 PM
Zaph: DAYTON PT2B-8 PLANAR TWEETER 69stingray Multi-Way 4 8th August 2006 05:25 PM
Line Array: NSB + Dayton PT2B Planar Tweeter ? thylantyr Multi-Way 5 27th January 2005 04:33 AM
Dayton PT2B-8 planar tweeter mazeroth Multi-Way 5 26th November 2004 09:49 PM
Page generated in 0.08064 seconds (81.99% PHP - 18.01% MySQL) with 10 queries
