Old 28th January 2005, 12:46 PM   #1
Default tube loudspeakers
I was wondering if anyone can point me at information,
about how to calculate build etc, the type of loudspeakers
from the following link
http://www.hawkaudio.nl/loudspeaker.htm
thanks,
Gene
Old 28th January 2005, 02:18 PM   #2
Send a message via MSN to noodle_snacks
One method would be to create a router template, then create a series of identical, hollow disks and stack them using glue, make two end caps and sand until smooth.
Another could use sonotube or similar (google).
Old 28th January 2005, 03:03 PM   #3
That page mentions PVC pipe in a couple of places; here's another project that uses PVC pipe in a similar-looking configuration.
http://www.partsexpress.com/projects.../Kuze3201.html
There are some construction details that might be helpful.
Loudspeakers Gary Hubbard Multi-Way 4 19th July 2009 04:00 PM
Tubes,Tube amps, Loudspeakers...You DREAM Here!!!From... nafanja Vendor's Bazaar 36 9th May 2009 11:06 AM
RFL Loudspeakers argonrepublic Multi-Way 9 26th January 2009 05:33 PM
loudspeakers sandys Multi-Way 2 25th March 2005 07:57 PM
loudspeakers konky Multi-Way 14 14th February 2004 11:22 PM
Page generated in 0.07135 seconds (67.79% PHP - 32.21% MySQL) with 10 queries
