Old 28th January 2005, 07:33 AM   #1
cominup is offline cominup  Viet Nam
Send a message via Yahoo to cominup
Default What driver????
Dear all,
I'm planning to build pair of woofer below:
1. 8"-12"
2. Could use with Petit Onken or Mini Onken.
3. Cut Frequency is 800hz (Cuz, my mid horn is the best from 800-1600hz)
4. Budget appx. $300.
I luv Leonard Cohen, Louis Amstrong and some soft bass. I'm looking for some JBL driver but there are so much Part Number then I'm so confusing
Thx in advance,
Cominup
Ill do it by myself
Old 29th January 2005, 12:22 PM   #2
OH!!! Please, help me. PLs, Pls!!!!!!!!
Ill do it by myself
Old 29th January 2005, 06:42 PM   #3
frugal-phile(tm)
planet10's Avatar
Somewhere out there is an Onken calculator spreadsheet... only specific ranges of drivers work in them. I'd try to find that and start plugging drivers into it to see what works (haven't done so myself)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th January 2005, 07:07 PM   #4
frugal-phile(tm)
planet10's Avatar
The only links i could find.
http://www.studiomaudio.com/onken.html
http://www.diyaudio.com/forums/showt...740#post364740
(this has a link to the calculator at the end)
http://home.hetnet.nl/~geenius/Solo103.html
dave
Old 29th January 2005, 08:55 PM   #5
ScottG is offline ScottG  United States
Notice that Supravox specifically uses the jensen "porting" for their 285GMF driver
http://www.supravox.fr/kits.htm#Jensen
http://www.supravox.fr/haut_parleurs/285_GMF.htm
They are less than 300 (each)
If you can use a lower "q" driver then consider the Beyma 12G40
http://profesional.beyma.com/ENGLISH/producto.php
or an even lower "q" driver (that costs less) then consider the OEM Ciare 12.75WI
http://www.ciare.com/oem/index.html
perspective is everything
Old 31st January 2005, 02:57 AM   #6
THanks all,
I've check and have some more confusing. May be I have to change plan from mini-onken to petit-onken, means change driver from 10" to 12"
My friend recomended me some JBL driver such as 2235; 2226 and their price appx. $500/pair-used. I hvn't enough bucks rite now.
So, I think that I will build a pair of petit-onken and waitting for any driver could match with!
So, when you were building petit-onken, what did you get, could you tell me about some experience, some tip and trick, some improving, some changing you did to get your private mood. It's more interesting than just build it up with exactly the same with basic design, isn't it?
regards,
Cominup
Ill do it by myself
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.09119 seconds (76.97% PHP - 23.03% MySQL) with 10 queries
