What happens if i connect the Vifa woofer below to a plate amp with a crossover between 60 and 120 hz?
Kind of an odd question, but can this be done to where it will sound reasonable? http://www.partsexpress.com/pe/pshow...number=297-310 Thanks |
#2 |
Reasonable is in the ear of the beholder...
Jesus loves you. |
#3 |
The P21WO requires a biggish volume to produce good bass. You would do far better using an M26WR which actually requires a smaller box !!! or similar 10"or 12",
#4 | |
just another
Out of interest Andy, what size box for the M26? I'm running mine in about 70L vented at the moment (can't remember the tuning).... though when I rebuild the cabinets I was thinking of making them a little bigger (80 - 85L). Tony. |
#5 |
normal vented is about 50L tuned to 30Hz with a 75mm diam port 240mm long
extended bass, 95L tuned to 25Hz with a 75mm vent 145mm long. this is using T/S as provided in BB6. Hope that helps ! |
#6 |
just another
Thanks Andy, I hadn't tried simming as big a volume as 95L!! I'll give that a try.
Even the 50L 30Hz seems very different to what I have at the moment! I seem to remember unibox coming up with 65L as the optimum (for flat) when I simmed it (had a 70L box already so just wacked them in it, and tuned it based on best sim in unibox (I can't remember the tuning freq, checked my notes and didn't write it down, lost the speaker workshop files with a HD crash too, doh). funnily enough I found some notes I scribbled and it had dimentions for a 93.5L box with THE ONE!!!! beside it..... so I must have been simming at those volumes after all. Tony. |
| Vifa 8 inch woofer | MTruslow | Multi-Way | 1 | 8th January 2009 02:24 AM |
| WTB: One Vifa P17WJ00-04 Mid-Woofer | GordonW | Swap Meet | 1 | 29th September 2008 04:11 PM |
| Vifa P22WP-01 8" woofer? | mgraves | Multi-Way | 29 | 7th January 2008 01:44 PM |
| Vifa TC woofer | paintrodsey | Multi-Way | 2 | 7th May 2006 06:49 AM |
| Vifa woofer substitution | Elkaid | Multi-Way | 4 | 8th April 2003 02:49 PM |
| Page generated in 0.09306 seconds (72.95% PHP - 27.05% MySQL) with 10 queries |
