Old 26th January 2005, 11:56 PM   #1
Mats J is offline Mats J  United States
Default Which Plastic
If I wanted to make a dipole with a plastic baffle, AND have the baffle be an opaque (sp?) color, which type of plastic sheet should I buy. Mind you, it has to also be machinable with standard "garage" wood working tools.
Old 27th January 2005, 12:07 AM   #2
SY's Avatar
Corian or something like that could be quite cool.
If there's a sucker born every minute, where do the rest of them come from?
Old 27th January 2005, 03:58 AM   #3
bzdang is offline bzdang  Canada
bzdang's Avatar
Depends on allowable cost, and method of assembly - do you want to bond parts together or fasten with screws? A plastic supplier from the yellow pages should be able to tell you what materials, thicknesses and colors are in stock, and will be able to cut your material to the part sizes that you need.
Here's a place to look at...
www.gepolymershapes.com
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 27th January 2005, 04:35 AM   #4
bzdang's Avatar
Cast acrylic is much much better to cut and drill than extruded acrylic.
Old 27th January 2005, 12:46 PM   #5
Paul W is offline Paul W  United States
Paul W's Avatar
While Googling for plastic one day, I found a web supplier listing dozens of different plastics and their primary characteristics on one chart. If you can find that page, you'll likely find your solution...and be able to order it at the same time.
Plastic TLs Geoff H Full Range 24 12th November 2006 02:27 AM
bonding rubber to plastic Keith D Everything Else 5 31st August 2003 06:51 AM
plastic give me a name Multi-Way 4 5th June 2003 04:11 AM
Plastic baffles? dc Multi-Way 5 21st April 2002 03:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
