Old 25th January 2005, 05:53 AM   #1
rv1890 is offline rv1890  Armenia
Default vifa pairing
I have a pair of Vifa P17Sj woofers laying around....(#297-308)
I was wondering if the Vifa DX25TG's (#264-578) would be a good match for them??.
After reading and researching I have come up with these tweeters as being a good match ...am i right?
IN case you guys want to glance at the specs..
P17(woofer): 40-5K...87db
DX25Tg(tweeter): 2K-40K....Fs: 650Hz....93.5db
let me know if Im learning this stuff correctly before i start building...
Also if u think theres a better tweeter for the job that Vifa makes.... let me know....thanks guys....(any crossover point suggestions)...i was thinking between 2.7K and 3K???
Old 25th January 2005, 06:32 AM   #2
just another
wintermute's Avatar
Looks ok to me
rather than just looking at the posted freq response range, it's allways good to look at the freq response curves too.
http://www.d-s-t.com/vifa/data/p17sj-00-08c.htm
http://www.d-s-t.com/vifa/data/dx25tg05-04c.htm
You can see here when looking at the two that there is a good overlap between the two drivers if crossing around 2.7K as you have indicated though I'd be considering crossing a bit lower than that, as the off axis on the mid bass starts to get worse at around 2K (and the tweeter should be able to handle a 2K crossover).... and the other thing is that there are no nasty frequency response peaks which should make the job of making a crossover that much easier.
You will need to pad the tweeter down (with an L-PAD) quite a bit, but that's no major problem
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 25th January 2005, 07:21 PM   #3
Thanks wintermute.
Pairing odd-bod Tannoy 15's? Brisso57 Full Range 1 13th November 2008 04:31 PM
Pairing the Seas Magnum with the E0045 woofer gottagettubes Multi-Way 0 5th October 2008 12:07 AM
Hidden audio goodies (ideas for an odd driver pairing) copper Multi-Way 4 31st August 2005 03:48 AM
Needed: Tweeter data sheets and pairing recommendations Jennice Multi-Way 5 10th July 2004 08:02 PM
Best 500Hz and down woofer for pairing with ESL? Bas Horneman Planars & Exotics 55 6th August 2003 01:44 PM
Page generated in 0.07356 seconds (67.53% PHP - 32.47% MySQL) with 10 queries
