Old 24th January 2005, 04:16 AM   #1
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
Default Horn-loaded Adire Extremis?
This is my first time playing with Hornresp, so I don't know if I got it right, but with a 100-watt input, I get a predicted output of 125 dB down to 40hz! Out of a 7" driver! Wow. (It looks like it probably stays withing excursion, too.) Predicted response is +/- 3dB from ~38hz to ~200hz--which is exactly my goal. Yay!
I'm toying with this exclusively for P.A. purposes, FYI.
The downside is that the horn mouth is 3000 square centimeters (or about 21.5" on a side) and the length of the horn would have to be 3 meters. (!)
Has anyone else modeled this driver for horn? Has anyone built an Extremis horn yet?
Old 24th January 2005, 04:36 AM   #2
Speakerholic
Cal Weldon's Avatar
Isn't the 13 mm Xmax a bit much for a horn?
I have the TB 6.5 long throw (11 mmXmax) and I wasn't aware that it might model well in a horn. If that's a posibility then I might change my plans for it.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th January 2005, 05:43 AM   #3
Nappylady's Avatar
I've not looked at the TB offering. I think I was driven away by the combination of low power handling and low efficiency. I'll certainly give it a look now...
The actual qualifications for a good horn speaker are more in having a low Qts and factors causing higher Fs (light cone, tight suspension, etc)
Reference: http://melhuish.org/audio/horndriver.html
Looking at folding over the Extremis horn, it's absolutely huge, so I think I'll model a couple different things before I commit to a plan of action. The TB driver is next on the list...
Old 24th January 2005, 12:33 PM   #4
Banned
The Extremis works very well for a direct radiating application in its size class, but is less than ideal for a horn. With a Bl of 9 it won't operate to full power to the bottom of its range into the high acoustic impedance of a horn. HornResp is fine for predicting the small signal response but it cannot predict what will happen when you put any real power into the box.
The Extremis also isn't cost effective. The TB W8-740c, which does have horn-worthy specs, runs about half the price of the Adire, and the MCM 55-2421 about a third. Either mounted in a 3.5 cubic foot folded horn can easily provide 105dB output at 28Hz with 100 watts input.
WTB: Adire Audio Extremis 6.8 b_force Swap Meet 4 11th July 2008 11:03 AM
Adire Extremis 6.8 phibes Multi-Way 27 15th April 2007 05:45 PM
Anybody know anything about the Adire Audio Extremis? 454Casull Multi-Way 106 2nd December 2004 02:25 AM
Horn loaded Adire Tumult eRiCdWoNg Multi-Way 6 29th June 2004 08:59 PM
Page generated in 0.07222 seconds (73.29% PHP - 26.71% MySQL) with 10 queries
