Am I getting needlessly complex? - diyAudio
Old 24th January 2005, 02:20 AM   #1
Mr Teal is offline Mr Teal  Canada
Question Am I getting needlessly complex?
I'm just in the planning stage of my next speaker project, which will be my first that's not a predesigned kit. It's quite exciting, but a little scary. As such, I'm going to be using active crossovers (either analog or digital, such as the kx project) so I can monkey with the crossover with little cost. The amp would be 6 x parallel LM4780 unit, giving about 100W into 4 ohms.
My design goals make this different from most of the 3 way projects I've seen on this board. I live in a one bedroom apartment, and my main room is ~12' x 17', with two openings on opposite ends of a 17' wall, a 6.5' opening leading to a small kitchen and a 3' opening to the enterence. My TV is in a corner of the room, on the same 12' wall as the opening to the kitchen.
Space is a major goal, the footprint of the speakers should be as small as possible. In addition, they have to be shielded. I'd like to keep the cost of drivers at under $200/speaker.
Right now I'm thinking of using an Extremis 6.8" for 200Hz and down, Dayton Reference 5" (RS125S-8) from 200Hz up to however high I can push it, and an inexpensive tweeter from there on up. The extremis would be in the Adire recommended 21L 33Hz ported enclosure.
Thing is, the Extremis seems to be good all the way up to 4 kHz with no issues. In your opinion, will the 200-3000 or so range be noticably better with the dedicated midrange? My instinct says yes, but I could use some input.
Old 24th January 2005, 02:42 AM   #2
RJ is offline RJ  United States
There are issues with the Extremis 6.8 that high.
Read through this thread for all your info;
http://www.madisound.com/cgi-bin/dis...gi?read=332714
How complex to make an amplifier ? (lighthearted) Bigun Solid State 52 6th July 2009 10:39 PM
Complex Exponentials Travis Gibby Multi-Way 4 28th December 2005 10:15 PM
Passlabs Becomes Complex A'af Pass Labs 17 16th October 2003 04:22 PM
Complex Emitter follower Banfi T. Solid State 104 1st April 2003 11:05 PM
Copyright 1999-2017 diyAudio
