i cant decide wich unit i should use for my next project...
i have looked at peerles sds/hds.. vifa and seas.. it going to be 2 units and the ribbon in the middle any good ideas?? |
#2 |
The CA15RLY is my personal favourite. Use slightly larger cabinets than recommended by Seas. I have used as large as 17,5 litres vented pr driver, but that may make the drivers a bit unstable if you use "only" two drivers.
Live sounds better than HiFi. |
#3 |
yes i have looked at that unit... im going to supply with a sub or 2
#4 |
I am using 4 pcs of the L15RLY on each side, but have tried the setup with CA15 too. Those two are quite similar in the bass region. It does definately not need a subwoofer.
#5 |
thanks.. but im going for only 2 units in D'Apolitto design.. and then i decide if im going to use a sub or not...
by the way. how about ribbons and active xo?? is it possible?? |
#6 |
frugal-phile(tm)
Jordan JX92 or CSS WR125....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
i dont now those units.. where can i get them and why should i pick those??? |
#8 |
frugal-phile(tm)
http://www.creativesound.ca/details.php?model=WR125ST
http://www.ejjordan.co.uk/drivers/jx92.html dave
#9 |
thanks.. i like the jordan but i dont wanna use 700 euro on 4 units..
#10 |
frugal-phile(tm)
Except for the top end (and giving up 1.5 dB in sensitivity) the CSS is a stiff competitor to the Jordan and at $280 USD for 4 a whole lot more cost effective.
dave
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| Fountek JP3.0 ribbon tweeter - NIB | cdoggy81 | Swap Meet | 4 | 29th October 2008 04:15 AM |
| Fountek JP-2.0 5" ribbon tweeter pair | mazeroth | Swap Meet | 2 | 23rd May 2007 12:48 AM |
| Fountek ribbon question | murat | Multi-Way | 0 | 28th February 2005 08:05 PM |
| Page generated in 0.08714 seconds (79.45% PHP - 20.55% MySQL) with 11 queries |
