#31 |
I think you're right. I was kind of hoping NOT to buy a 1000 watt amp. This way I can still use fairly low power and it should blast. Right now I'm only running 50 w/ ch. through them w/ an Alesis amp and it's pretty darn loud. Got an old modified Adcom amp that puts out 430 w/ ch. into 4 ohms for when the JBL's go into the VOTT's. That should be plenty of horsepower for them.
Guy |
#32 |
Ya know, I just realized.......... both those amps are lame. Well, maybe not the Alesis......... it seems like it would make a great amp for a pair of 2441's or 2446's. Maybe some TAD 4001's?
Man, have I been out of the music world for too long. Got to stop spending money on jet skis........ How much are 3 new Crown Macro-Tech's gonna cost me? Argh............. Guy |
#33 | ||
#34 |
Hey man, I was just kidding.............. But yes, I will be using this system for P.A. use occasionally. I just thought it would be nice to have some new amps.
Guy |
#35 | |
If the rig is going to do dual duty, and you have the $, get some high power amps for PA duty, and something that'll sound better in the <5W region for home use. Even the direct radiators won't need that much power at home. It'll sound a lot better and remove that bleeding-ears-drive-you-out-of-the-room characteristic that I've heard with every PA amp powered domestic horn rig. The Crowns are often cheap as dirt on ebay. |
#36 |
Wonder what kind of db SPL I'll get out of the 2225's in the 210's ?......... With the original Altec 515B's I think they were rated at 108 db @1W / 1 meter on axis, 500Hz and below.... Got to check to make sure, but I remember that # was well over 100.
Guy |
#37 |
if you could time that 454casull you would have all the low anyone could ask for. what would the spl be on that wrist breaker be?
| EAW dual 18's | billybob | Subwoofers | 1 | 9th August 2008 10:07 AM |
| Dual B-139's | Moondog55 | Subwoofers | 27 | 19th November 2007 05:17 AM |
| dual primary//dual secondary toroid | larryg | Chip Amps | 22 | 6th September 2006 09:24 PM |
| looking for dual npn and dual npn smt transistors | sovadk | Solid State | 9 | 25th August 2005 10:58 AM |
| Dual 505-4 | gchrist | Analogue Source | 1 | 30th April 2004 06:51 PM |
| Page generated in 0.12741 seconds (59.57% PHP - 40.43% MySQL) with 11 queries |
