Old 22nd January 2005, 09:01 PM   #1
type is offline type  United States
Question Do you stuff a bass-reflex speaker?
I have two questions.
1. Do you stuff a bass reflex style speaker?
2. What do you think is the best 5 1/4" woofer?
Thanks.
Old 22nd January 2005, 09:40 PM   #2
pinkmouse's Avatar
1. In general, no, but sometimes a little on the walls helps.
2. How much money do you have?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 22nd January 2005, 10:14 PM   #3
Vigier is offline Vigier  Netherlands
2) Peerless HDS134, if you take cost in account (is that good english?)
Grtz,Joris
Old 22nd January 2005, 10:39 PM   #4
Bill Fitzpatrick's Avatar
"if you take cost into account" is the proper way to phrase it.
Old 22nd January 2005, 10:56 PM   #5
THNX Bill! This forum is good for my english, but bad for my bank account
Grtz, Joris
Old 22nd January 2005, 11:39 PM   #6
Volenti is offline Volenti  Australia
Stuffing damps the resonance of the driver and can reduce the output at resonance by up to 3db.
It can help SQ if the enclosure has a hump in the response around resonance but in a bass extended design it can reduce lower bass output.
Old 22nd January 2005, 11:56 PM   #7
Banned
You always stuff or fully line a reflex speaker if the woofer is running wideband, ie, higher than 300 Hz or so. If you don't internal reflections off the cabinet walls back to the cone will cause all sorts of peaks and dips in the response. On the other hand, for a pure sub that doesn't operate above 100 Hz you neither stuff nor line, as internal reflections are not a concern and SPL will be lessened.
Old 23rd January 2005, 12:00 AM   #8
SY's Avatar
It depends on the assumptions you made for box QL. For a "normal" choice of 7, line the walls but don't stuff the box. You can play around with stuffing if your measured response (or impedance) doesn't hit the target predicted by the T-S parameters.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd January 2005, 12:11 AM   #9
pinkmouse's Avatar
Is that enough differing opinions for you type?
Al
Old 23rd January 2005, 01:18 AM   #10
if Monday then you stuff. Never on Wednesdays...
interesting. i was about to put together a set of speakers, now i know to exect a little bit of EQ work.
if only it could be used for good, not evil...
css bass reflex paulfk Full Range 7 8th March 2009 11:25 AM
Two ports in a 2-way bass-reflex speaker alvinlim Multi-Way 3 15th February 2006 10:41 AM
8-12" Bass reflex Full range Corner speaker (mono) Howismydriving Full Range 2 23rd October 2005 07:50 AM
Bass Reflex Guss Multi-Way 1 15th December 2003 02:33 AM
bass reflex? GAK Multi-Way 2 23rd October 2001 03:04 AM
Page generated in 0.10568 seconds (73.89% PHP - 26.11% MySQL) with 10 queries
