Old 18th January 2005, 11:28 AM   #1
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Default Monacor MCE-4000
Anyone with experience with this mic capsule?
I want to build a measurement mic to measure freq. response of loudspeaker elements, and the panasonic WM-60/61 are hard to get here in norway. The MCE-4000 has good specs and looks like a decent candidate.
Check it out here
Old 18th January 2005, 01:39 PM   #2
Alcaid's Avatar
bump
Old 18th January 2005, 03:53 PM   #3
As far as I know this is the panasonic wm60 capsule. Sold by monacor in europe.
Old 18th January 2005, 04:41 PM   #4
Alcaid's Avatar
No, it's not. The specs are not the same:
WM-60A:
Sensitivity –44±5dB
Frequency 20–20,000 Hz
Impedance Less than 2.2 kΩ
S/N ratio More than 58 dB
Max. operation voltage 10V
Standard operation voltage 2V
Current consumption Max. 0.5 mA
Sensitivity reduction Within –3 dB at 1.5V
Diameter 6mm
Height 5mm
MCE-4000:
Sensitivity 5mV/Pa/1kHz, ±3dB (equals -46±3dB)
Frequency range 20-20,000Hz
Output impedance 2.2kΩ
S/N ratio > 58dB
Power supply 1.5-10V DC current /0.5mA
Diameter 6mm
Height 5.8mm
Old 18th January 2005, 05:36 PM   #5
Alcaid's Avatar
Looking at the specs, the MCE-2000 looks a lot like the WM-60A.
Old 18th January 2005, 06:56 PM   #6
sorry my mistake. It's the mce-2000 that's the panasonic
Old 19th January 2005, 08:37 AM   #7
Geenius is offline Geenius  Netherlands
Geenius's Avatar
And it comes out as the best in this months Klang&Ton microphone test: Klang&Ton
They also explain how to build your own mic using the MCE-2000 capsule.
Tony
Old 19th January 2005, 08:52 AM   #8
Do u need a calibration curve? and if so, where can you get one?
Old 19th January 2005, 11:24 AM   #9
Alcaid's Avatar
Was it the MCE-2000 that came out best? What other microphones did they test?
Old 19th January 2005, 12:50 PM   #10
Geenius's Avatar
If I remember correctly the MCE-2000 came out best. They also tested the MCE-2500, MCE-4000 and the MCE-4500. I'll check the article this evening to make sure.
Tony
Threshold 4000 R-K Rønningstad Pass Labs 10 28th August 2009 05:27 AM
Monacor MCE-4000 sploo Multi-Way 10 19th July 2007 11:49 AM
Page generated in 0.10030 seconds (78.44% PHP - 21.56% MySQL) with 10 queries
