Gale GS401
Gale GS401
Old 16th February 2006, 11:45 PM   #21
stera66 is offline stera66  Serbia
There is a place for you in HI-FI heaven.
Thanks a lot
Old 17th February 2006, 03:11 PM   #22
Just realized that speaker should stand on the longer side. Comparing to modern speakers “laid “ on the side.
Where they all with the stands or you just put them on the floor?
They are like ‘central’ speakers at surround systems, aren’t they?
I recalculate front mounting plate only and would appreciate if you check my picture.
Specially front panel measurements, without ¾” thick cabinet walls.
They look very unpractical for keeping them in the small rooms (if you keep them as you should –side way). I found this on the Web http://www.nanson.ch/features/2005/gale.html
Hope that he is going to update site. It promises to be art project.
Unfortunately my woofers where in bad shape and I recone using Kevlar cones and rubber surroundings , so they want be classical restoration and update.
Do you have idea how much they worth today?
Old 17th February 2006, 10:55 PM   #23
alpha_03 is offline alpha_03  United States
Yep, those are exactly as they should appear. Matter of fact, I have the exact same model as shown in the picture.
The GALE speaker company is now based in Tawian, and they do not offer any thing for the 401's to my knowledge, however, the mids are available from previous links posted here in this thread and you could recone your woofers to their original configuration via the same links I previously mentioned- I believe kits are available from England, but I do not know exactly from whom, I left that to the speaker re-builder.
A very good replacement for the woofers are the Madisound Silver Flute Wool Cone 8" drivers- they are drop in replacements and have nearly the same build parameters. The same mid-range driver was also used in 70ish Allen organ speakers, and a few other higher end/industrial designs, the tweeter is an Allison, which is widely available on ebay - I believe it to have been actually made by SEAS, but I am not sure on this.
I suppose one could change the drivers placement with in the front baffle, maybe center align all the drivers for vertical placement rather than horiziontal placement, but then they wouldn't be Gales any longer would they? More of an MTM with a mid-range installed. However, they may be much more practical for some users in your proposed configuration. You wont know unless you give it a try- build two front baffles, one of each design, and allow for it to be removable/interchangable with the use of a gasket and screws, then you will know for sure which design you prefer.
Eventually, I plan to use mine for upper and lower center channels in my HT set up, all be it they are very-very good all out music monitors as well. Even so, You might be very supprized, they produce very good bass for their size and stature, and will play very high SPL if feed good clean power from a well designed amplifer.
"Faith based engineering......now that's a new one."
Old 21st February 2006, 06:23 AM   #24
Default Gale -made in ...
How come that there is Gale’s made in England and other made in USA??
Is there any difference?
I read somewhere that some people have GS 401 with “power handling 100W” while all the others 200Watts?
For some reason all my post are checked first and I don’t know if I can post pictures. I found couple interesting things.
I will keep Kevlar membranes and original box design. Maybe just some different shape of front grill .
Somehow believe that if I change box it would be bad.
Old 21st February 2006, 06:03 PM   #25
One more question.Please can you help me with this two dimensions?
what are dimensions A and B , from my picture?
I didn't get it.Because this part for the front grill mask looks much biger than 1/2".
Please help.
Old 22nd February 2006, 12:46 AM   #26
Sorry, I cant help with that mesurement, I have the 401 C version and mine do not have that over hang on the cabinent. However, I am willing to bet my previous mesurements I gave you are the same as your cabninets, just no Grill over hang as you have in your picture, therefore that mesurement is moot.
Alpha
Old 22nd February 2006, 09:45 PM   #27
hey Bez, are you refering to a wire wound 10watt like this one? or, some other type of resistor?
http://www.partsexpress.com/pe/pshow...tnumber=016-5K
or one could use these to up the power curve I presume?
http://www.partsexpress.com/pe/showd...tnumber=017-2K
and
http://www.partsexpress.com/pe/pshow...tnumber=016-1K
presumably, one could replace the old pots with these- http://www.partsexpress.com/pe/pshow...23-520&scqty=4 However, I am not sure if 1/2 a watt would suffice in that circut path. The original Gales use a ceramic pot, so correct me if I am wrong, but the above probly wouldnt work at high power levels- they would probly burn out.
I also wonder if standard 10% caps would be a good replacement?
Old 23rd February 2006, 01:36 AM   #28
here is some additional info reguarding Gale Loud spekers- some good reading-
http://www.kabrna.com/hifi/gale_review.htm
Old 22nd March 2006, 08:35 AM   #29
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
Hi All,
I re-built my Dad's Gale GS401c's (shown in my sig) about 10 years ago. I used peerless replacement drive units from Wilmslow audio and replaced all the caps. I also took the mid and trebble adjusters out and fitted new cable throughout the box, one of the main incomming cables to the crossover is only about 1 mm thick in the original installation!!
Initially i was worred that the speakers would loose their characheter after the mod, as the new drive units look very different from the originals. This was not the case, they sound almost identical. The parts cost just over 300 pounds, which was incrdible vfm considering what you could buy new for that money, but it did take a whole day.
My advice if anybody is contemplating this would be to get all new parrallel thread driver mounting screws with metal threaded inserts on the inside of the box. The metal inserts with a wide area would be best, as the chipboard baffle is very weak.
We use a Quad 405 I for driving them, they make this powerful amp sound weak, anything less would not be ideal IMO. A cheap driving solution would be two Quad 405 II's, one for each channel.
Also, they really need a pre-amp with a bass control, the bass from the speaker itself can very easily become overblown if they are near a wall or corner.
We will pay the price, but we will not count the cost...
Old 20th April 2006, 08:20 PM   #30
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
http://img206.imageshack.us/my.php?image=9aa5gg.jpg
Gale GS401Hide this!Advertise here!
Gale storm 8 delphiplasma Subwoofers 12 30th March 2011 12:48 PM
Gale storm8 schematics delphiplasma Subwoofers 1 21st October 2009 10:30 PM
Gale 401 C's Graeme Hancock Multi-Way 0 10th January 2007 08:46 AM
gale gs401a jshaffdds Multi-Way 1 24th October 2006 07:52 PM
Gale 3040 Loudspeaker eranrund Multi-Way 0 19th June 2003 07:53 AM
