I've almost decided on my next project, I want to go with the dayton tweeter and the NSB.
I'm crossing at 6k and I'm not sure what network to use, I understand the differences between say a 2nd degree and a 4th degree, but how big of a difference does the phase change make? Also, Do you have to cross an octave above the Fs or the frequency response of the tweeter, lastly, what good reading on crossovers so I don't have to ask small questions such as these? Thanks, Matt |
#2 |
If you don't have it already, get a copy of Dickason's Loudspeaker Design Cookbook.
Re your specific question, the audibility of phase shifts in this range and of this magnitude is questionable. Sloppy polar patterns and deviations in frequency response, OTOH, are unquestionably audible. The 4th order makes for a cleaner polar pattern, less sensitivity to driver offset, and better power handling. Make sure, though, that you understand the difference between a 4th order electrical and 4th order acoustic response!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
FYI
I just built some speakers using the NSB's and the Dayton tweeter. Four NSB's and a neo in a MMTMM sealed .87^3 ft box. The crossover was 2nd order at 4800 Hz. I installed a switch in the proto crossover board for phase reversal for testing. I couldn't hear difference and neither could several test subjects. |
#4 |
Thanks guys, I think I'll go with 2nd order this time and experiment later, every penny saved counts
#5 | |
A) You reversed the phase of the signal going to your woofers/tweeter combo as a unit, leaving the phase relationship between the woofers and tweeters intact? or B) You reversed the phase of the woofers in respect to the tweeters?
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#6 |
The answer is.....
B |
#7 |
Then I don't think you have a true even order crossover, which should yield a deep null when the correct polarity is reversed.
James |
#8 |
It looks like a textbook 2nd order to me. Coil & cap to woofer, cap & coil to tweeter. Cross is 4800.
I'm all ears and willing to learn. |
#9 |
The null when the tweeter phase is wrong is deepest when the drivers are phase aligned. This implies that if they are not aligned the notch will not be so deep. if far enough off there won't be an audible difference.
Somebody was kind enough to post an excel file a while back called something like "driver offset response calculation." a search ought to turn it up. Whoever did it did it at work and didn't change the author info so I don't know who to credit at 4800 hz, 2nd order bessel, you'd only get a low Q 5 db dip around 4KHz if the drivers' acoustic centers are 1 cm out of alignment. |
#10 | |
Phase is important, but it is not some magical/mystical word. I will say that the design of a crossover without measurements is possible, but not very likely to be successfull in an objective sense; although you may be quite happy with the results.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
| Do connecters matter? | AdamThorne | Everything Else | 8 | 15th December 2006 09:17 AM |
| What exactly is beaming and why does it matter? | paulspencer | Multi-Way | 101 | 12th June 2006 11:29 PM |
| dipole sub H-Frame, phase or opposite phase ? | mbon | Multi-Way | 6 | 19th June 2004 08:36 PM |
| Does Voltage Matter? | soundNERD | Chip Amps | 36 | 27th November 2003 06:21 PM |
| Size does matter.. | dutch diy | Multi-Way | 3 | 19th July 2001 09:30 PM |
| Page generated in 0.11744 seconds (82.60% PHP - 17.40% MySQL) with 10 queries |
