How much flux do you lose if...
Old 18th January 2005, 12:23 AM   #11
454Casull is offline 454Casull  Canada
Is the only effect of the circulation of eddy currents flux modulation? Or is some other product of the eddy currents that causes distortion?
Old 18th January 2005, 09:05 PM   #12
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
Hysteresis, too, if the eddy currents are flowing in ferromagnetic material.
lamination is certainly a positive thing to do if you have to put ferromagnetic material with low resistivity in the gap. However I don't believe it treats the whole problem.
In a moving VC motor, you've got two things happening: the VC field is being dragged axially through the gap creating eddy currents reciprocal to its motion (for which stacked laminations are an ounce of prevention), but you've also got circumferential currents forming in response to the current cycling in the VC.
How much flux do you lose if...Hide this!Advertise here!
Did you lose a case of CD's at RMAF? Jon Ver Halen Pass Labs 0 20th October 2008 02:34 PM
Help: Need to lose some volts Decker Chip Amps 15 7th October 2005 07:47 AM
Do I lose power when parafeeding? Bas Horneman Tubes / Valves 2 26th March 2004 02:30 PM
I could lose some heat - suggestions? 7V Tubes / Valves 11 1st February 2004 12:56 PM
