Old 17th January 2005, 12:23 AM   #1
roystr is offline roystr  United States
Send a message via MSN to roystr
Default i was reading about a speaker that had the crossover
set at 15ohms. it was the "LS3/5a " it seems it was made in england for the BBC.
i never heard of a speaker having that high an ohm level before. could anyone give me the quick info on the why/what for and could i run them speakers on my new pioneer reciever? or is it a "tube" amp thing??
thanx ,
roy
Old 17th January 2005, 12:42 AM   #2
TerryO is offline TerryO  United States
TerryO's Avatar
Two things; first, this is the fullrange forum and the Ls 3/5's aren't. Second, the BBC licensed the design and several companies actually produced them over the years and were evidently produced as an 8 Ohm later on. They are a "Classic" design and sound pretty good, but they don't play loud or low, although a pair of subwoofers can correct some of that.
The question about SS amps and these speakers seems to be your main concern, and yes, they'll work just fine. In fact, some think that SS amps actually sound better driving a higher load, a lot of misinformation floats around about this, semingly from people that cut their teeth on car audio instead of the other way around.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 17th January 2005, 12:47 AM   #3
Default thanx terryO,ill keep my posts where they belong.NT
crossover for coaxial speaker jrazor Multi-Way 3 8th May 2008 12:26 PM
PS for Active Speaker Crossover speakerguy79 Power Supplies 7 1st January 2007 05:44 PM
Crossover at speaker level? icebear Multi-Way 0 23rd November 2005 12:52 PM
Can you use a 8 ohm crossover with 4 ohm speaker? Bull Subwoofers 1 19th May 2005 08:37 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.07528 seconds (73.89% PHP - 26.11% MySQL) with 10 queries
