Old 14th January 2005, 05:59 PM   #1
Default Rear Mounting Tweeters
If I rear mounted the PE 49 cent Onkyo 3/4 inch tweeters in a line array the closest I can space them is 2.25 inches (because of the diameter of the rear magnet).
If I rear mounted them to a baffle 1.5 inches thick and angled the opening each driver would be mounted in the throat of a mini horn.
The crude pic of what I'm thinking of follows. Would this have a an adverse effect on the sound of the tweeters or the array?
Probably a silly question, but ........
Old 14th January 2005, 07:00 PM   #2
think I got the pic here
Old 14th January 2005, 07:05 PM   #3
don't know how but the image is in everything else under
"attaching image - help"
Old 15th January 2005, 02:25 AM   #4
Anyone chip in with some info or point me in the right direction??
Old 15th January 2005, 02:41 AM   #5
Illusus is offline Illusus  Canada
Illusus's Avatar
With just an angle cut like that you end up with a plain conical horn, notthe best contour for a HF horn. A tractrix would be ideal but it would be a real tedious task by hand, I guess if you're really 'tenacious' in nature you could shape your own router bit contour...but those are most likely not the wanted routes. A round over bit would probably do the job better than an angled cut. You'd, at least, get away from that sharp edge at the mouth of the horn. That edge may induce unwanted diffraction effects. Blow through a drinking straw at a sharp adge, then a rounded adge, you'll hear the effect.
You can actually see how your horn may perform by using Hornresponse; you have the throat area, mouth area, horn length...pretty much all you need for a good guess.
Give the conical horn a try, at least shape the mouth edge with some sandpaper. It won't be too hard to try one driver in a piece of scrap. While you're at it, try a few different angles and roundovers, see what sounds best to you.
Fighting the program since 1976.
Old 15th January 2005, 03:43 AM   #6
I couldn't draw it but that is what I thought of. Angle out the tweeter hole and then use a 3/4 inch roundover bit to eliminate the sharp edge on the face of the baffle.
How steep an angle should the hole flare out? I'll crossover to the tweeters at about 4.5K -5K.
The throat is 1 inch and the hole at the front of the baffle is a maximum of 2.25 inches.
I suppose I wasn't sure if how thick of a front baffle I needed (.75 - 1.5 inches) to get from a throat of 1 inch to an exit of the horn of 2.25 inches at the optimum angle.
Thanks for the help.
Old 15th January 2005, 07:11 AM   #7
frugal-phile(tm)
planet10's Avatar
I haven't done the assymetrical thing with 2 tweeters (but have with some tractrix PA mids), but often use the technique to act as a waveguide on super-tweeters to get a better match with the FRs.
The picture is a closeup of an MTM designed for ceiling mount (3" thick overall)...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
8inch woofer rear loaded horns with tweeters Naudio Full Range 1 10th January 2009 09:54 AM
Rear tweeters bzfcocon Multi-Way 6 12th February 2008 07:22 AM
How To Add Rear Tweeters to System? fastcat95 Multi-Way 1 21st February 2007 12:35 AM
Sale or trade - tweeters for concentric mounting Illusus Swap Meet 0 18th November 2004 12:49 AM
Heil tweeters mounting Andypairo Multi-Way 2 13th May 2003 12:54 PM
Page generated in 0.09661 seconds (68.37% PHP - 31.63% MySQL) with 11 queries
