Hello.
I have a ste of KRK V6 monitors.they sound ok.But I have been toying with the idea of using the plate amp for a different project. The v6 uses axon orca drivers,wich are good for their low price.Now im thinking of using higher quality drivers to make a better speaker in a homemade box.Basicly using only the amp wich seems nicely built. I told you this was a crazy idea did I not? here is some data for the original drivers: axon orca bass 6.5 inch 6s1 Specifications Nominal Power Handling (W) 50 Sensitivity 88.1 Fs 55.76 Vas 13.76 Qts 0.47 Qes 0.56 Qms 3.02 Sd 113.10 Mms 10.63 T1s 0.75 dome Specifications Nominal Power Handling (W) 50 Net Weight (kg) 0.53 SPL 90 Ferrofluid damped. * Power handling: 50 watts RMS/75 watts max * Nominal impedance: 8 ohms * DC resistance: 6.4 ohms * Frequency range: 2,500-20,000 Hz (UHH,WHAT?Look at the specs from the amp...) Magnet weight: 3.7 oz. * Fs: 1,550 Hz * SPL: 90 dB 1W/1m * Net weight: 1-1/8 lbs. * Dimensions: Overall Diameter: 4", Cutout Diameter: 3-3/16", Mounting Depth: 1-3/16", Magnet Diameter: 3-3/16". the plate amp is activly crossed at 1.9khz I dont know the slope of the xo and the amp gives 60w to the woofer and 30w to the tweeter. I can use win ISD to model my bassresponse but I would like to have some input on the choice of drivers... For woofer I like the dynaudio or phl drivers maybe the extremis from adair audio.I d like a better bass response than a 6.5 unit would usually produce. An 8 inch would be a better choice I think. Theese speakers does not need to be shielded.I dont want to have to use a sub with theese but I need to hear what is going on down there,and Im ready for a speaker with less bass and a low Q As for tweeters I like the Wave guide units from vifa or sililar High end units... The V6 have a 2 db difference between the two drivers. And it seems like the high end on the speakers are somewhat dull. What say you audio wizards? I just dont know,but it seems like a fun project. Oh, BTW I dont expect to come out in the end with something sounding like a really nice pair of ADAMS or genelec. Just good ol nice DIY.
thanks for reading. H.Honda Chico CA Land of the fooled |
#2 |
why not use eton 7-372/32 woofers and for example a vifa tweeter, this will sound almost as good as a pair off active
adam monitors, it all depends on how much you want to pay for a good monitor speaker i mention both drivers because i have used them in a active setup the eton woofer in a 18 litre cabinet with the vifa tweeter crossed at 2.8 khz , the amplifiers are 130 w for the bass and 70 w for the tweeter
Ralf |
#3 |
The Volt BM220.8 is apparently a favourite among some expensive monitor manufactorers. It has a plastic cone, very linear, can be pushed very hard, and has a v flat frequency response up to 3.5K. Around $220CAN from solen.
sardonx
The End |
#4 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 | |
The End |
#6 |
ain't this eton woofer hexacone? I've read, that those can be really nasty in terms of distortions. Read http://ldsg.snippets.org/vendors/eton.php3
qubix |
#7 |
It may be that the quality of the plate amp is appropriate to the quality of the drivers. This project doesn't make much sense. A crossover is designed for specific drivers typically, whether active or not. You may get lucky if you match sensitivity exactly and it's a generic 4th LR or something. Much of the what makes a good speaker good is the design, not the components.
BTW, Genelec monitors generally use Seas drivers AFAIK. Adams use Eton. Seas drivers aren't too expensive, and wouldn't be a bad way to go. You may get lucky. GB |
#8 | |
#9 |
Thanks... I'll be buying them after the 7" Revelators. Sardonx
The End |
#10 |
"This project doesn't make much sense. A crossover is designed for specific drivers typically, whether active or not. You may get lucky if you match sensitivity exactly and it's a generic 4th LR or something. "
Yes i know it doesent really make sense....crazy i told you all at the start.But I have the parts and would like to do something fun. Iam willing to bet that the xo is simple.Thanks for the input on the drivers. ill just match the 1.9 db difference and hope for the best....
| Studio monitor | sueyuen3 | Multi-Way | 4 | 13th April 2009 02:13 AM |
| Studio monitor | gev | Instruments and Amps | 30 | 17th January 2006 06:53 AM |
| J-Low as a Studio Monitor? | atticus | Pass Labs | 2 | 22nd August 2004 08:37 PM |
| DIY studio monitor | mgoedeke | Multi-Way | 4 | 22nd June 2003 02:29 AM |
| My amplifier ideas (crazy) | Duo | Solid State | 38 | 27th June 2002 09:32 AM |
| Page generated in 0.11284 seconds (81.49% PHP - 18.51% MySQL) with 10 queries |
