Found this on a website from Austraila (Andy G's). He responded to my email but couldn't remember where he got the pic.
Anyone know where i can find it? or Where I can find details on small(er) back loaded horns? Phil |
#2 |
I dont remember the site. is the JAPAN site, is for sales site
use google, only replys in JAPAN and in this time IŽn search for TQWT or full range or horm |
#3 |
If it helps, that looks like the enclosure fabrication technique one of the members here tried. Multiple layers, CNC routed as required and glue together.
Jesus loves you. |
#4 | |
Phil |
#5 |
Banned
That design looks really neat but all those fancy rounded bends serve no purpose as it's a rear-loaded horn intended to work only in the bass, 100 Hz or so and lower, while rounded bends and other reflectors have no effect below about 200 Hz or so. The smallest possible backhorn would be a spiral design with no space wasted on wide radius rounded bends.
#6 |
It's only a hobby |
#7 |
The source is a Japanese website:
http://www.spnet.ne.jp/%7Ehasehiro/p...kroadhorn.html Notice that it's a "backRoaded" horn. LOL In the near future I'm going to try something similar, but with styrofoam except for the side panels of plywood. Hot wire cut the entire horn out of a block of styrofoam. Then epoxy and fiberglass for rigidity and smooth the pathway of the horn. If the first test shows I need more rigidity, then after cutting the horn, I can slice the styrofoam vertically into a few slices like the mdf horns pictures. Sandwiching some epoxy layers will definitely give sufficient rigidity combined with the interior surface covering. A truly easy to build very light back horn will be the final result. I also have plans to do a styrofoam version of the Jensen Imperial back horn. For it I will have a narrow top and wide bottom, so no parallel walls, better throat shape, and what is usually a 300lb speaker will be well under 100lbs. I bring these projects up because seeing the smooth horn contours of those layered mdf horns gave me the idea to use styrofoam. Initial tests of the strength of styrofoam with epoxy and fiberglass are very encouraging.
Everyone has a photographic memory. It's just that most are out of film. |
#8 | |
I feel I have adaquate skills to laminate speakers of this type. Can anyone help me with details to build a small pair of these. I have no driver preferences. Thanks Phil |
| Using PVC Pipe For A Back Loaded Horn | JimOfOakCreek | Full Range | 13 | 15th April 2008 07:30 PM |
| Back loaded horn bipoles? What? Why? | kaltsoplyn | Full Range | 6 | 19th February 2008 11:37 PM |
| Front loaded and back loaded horn | DrWoofer.com | Subwoofers | 0 | 3rd August 2007 06:55 PM |
| Back loaded horn design (help please) | Puggie | Full Range | 3 | 23rd February 2006 01:08 PM |
| Back Loaded Horn Bending | Tyimo | Multi-Way | 15 | 17th April 2005 05:04 PM |
| Page generated in 0.09112 seconds (79.51% PHP - 20.49% MySQL) with 11 queries |
