Old 12th January 2005, 08:11 PM   #1
tdemont is offline tdemont  United States
tdemont's Avatar
Default final crossover schematic
have decided on a simple high and lo-pass passive crossover and L-pad attenuator design (for the tweeter), I have looked on the internet for a wiring diagram that includes all three linked together and can't find one. How do they link up?
Do I connect the positive and negative parts of the two crossovers together at the binding post and add the L-pad closest to the tweeter?
Also, if a resister is rated at 12 watts rms and it is 20 ohm or 1 ohm, how many watts can it handle from the amp before blowing?
Old 13th January 2005, 06:15 PM   #2
tdemont's Avatar
Default Maybe it will be easier if I post a diagram... Help Please
A hip diagram is attached. Please help, all I need is a nod if it is correct.
Old 13th January 2005, 06:15 PM   #3
tdemont's Avatar
Default Also... sorry to be such noob, but...
I used the tools recommended else where on this site
(http://www.carstereo.com/help/Articles.cfm?id=55#second)
to get the capacitor, resistor, and inductor types. Did I choose wisely?
Old 13th January 2005, 06:48 PM   #4
Bill Fitzpatrick's Avatar
That's the correct way to wire it.
I take issue with the attenuation resistors. No degree of attenuation results in those values.
Also, since this is a textbook crossover which cannot take into account the response curves of the drivers, it will only approximate correctness. A zobel across the woofer will help.
Old 13th January 2005, 07:14 PM   #5
tdemont's Avatar
Default Thanks. and about attenuation...
I know a zoebal requires measurement of inductance and DC resistance of the woofer, but I lack the equipment.
I think I picked a pretty common driver, is their a site that lists that information? Or is their some way to infer it from the impedance graph?
As far as the resistors go, I used the tool at http://www.carstereo.com/help/Articles.cfm?id=55#second and entered in 2 decibels, a figure slightly higher than the sensitivity difference between the speakers. Those are the values it gave me. (driver impedence = 4 ohms, desired attenuation = 2db gave me resistor recommendations which I rounded to the nearest available resistor at speaker city .822 to 1 and 15.44 to 15 ohms. Is that the wrong tool to use?
what resistors would you recommend for a 1.5db difference in tweeter and woofer sensitivity?
Thanks again.
Old 13th January 2005, 10:16 PM   #6
Sorry, my mistake. The 2 resistor values are correct but they are reversed.
As to the parameters on the woofer, see:
http://www.d-s-t.com/vifa/data/mg14sk09-08d.htm
Old 13th January 2005, 10:25 PM   #7
tdemont's Avatar
Default I think I found issue.
Redid calculations. Think attenuator is better now. R1=1.5 OHM, R2=6.0 OHM
Old 14th January 2005, 01:08 AM   #8
tdemont's Avatar
Default Thanks again. 50 mf capacitor?
Using the link you gave me, I found the stats for the FOUR ohm model, I then plugged those (DC resistance 3 Ohms, Voice coil inductance [H] 0.00045)
into the Zoebel circuit calculator (http://www.carstereo.com/help/Articles.cfm?id=55#second) ,
and I get a design using a 3.75 ohm resistor and a 50mF capacitor!
I can't even find 50mF capacitors on speaker city. They only go up to 20!
Old 14th January 2005, 03:05 AM   #9
They have it. You're looking for an electrolytic. It's $1.75.
Old 14th January 2005, 03:52 AM   #10
tdemont's Avatar
Default you guys know how to make a noobie feel welcome
You could almost charge for it... thanks again.
IMF Crossover Schematic vergebnisse Multi-Way 1 22nd December 2006 08:53 PM
Final schematic, I think? jaymanaa Tubes / Valves 10 14th July 2006 06:47 AM
crossover schematic rv1890 Multi-Way 1 9th February 2005 06:39 PM
Crossover schematic gilparente Parts 4 6th April 2004 04:35 PM
Anybody have crossover schematic? CryingDragon Solid State 11 20th September 2002 01:50 AM
Page generated in 0.09651 seconds (84.24% PHP - 15.76% MySQL) with 11 queries
