I have searched through the forums a little bit but am having trouble trying to find a Transmission Line box design for these. I will only be using one of these per TL. About 60w per in a fairly small room. I dont understand TL's that much...so a drawing with dimensions would REALLLLY help me out. Any help would be appreciated though. Thanks! (btw... I was referred here by Jim85IROC I think is his sn
)Will |
#2 |
Hi Will,
you could have a look at post 4 here. Thatīs the design Iīm using and am very happy with it. See post 44 of the same thread for measurements and another picture. Iīm using it nearfield with my PC but also tried it in a room with a sub. The latter works well enough in small rooms but is very SPL-limited with only one driver. I personally get away without a sub at my desktop but that depends on taste really.
jens |
#3 |
Mine will be :
Line length ===== 15.75" area at top ===== 18.6 sq in area at bottom ==18.6 sq in port tube =======0.492" diameter, 1.18" length driver position ===7.56" from top of line port position ==== 14.76" from top of line Can I get a drawing of the box with those dims on it? I dont get where the line length, area at top, and the area at bottom come in. I cant get a picture in my head of how that would look. Will |
#4 |
You can actually see the little pipe in post 15.
Area at top means the cross-section-area (youīll see the shortcut CSA here quite often) so (wide*deep). In my case the original designs was 40cm high, 12cm wide and 10cm deep. Thatīd be 15,75*4,72*3,94in^3.(inner measures!!) Please keep in mind that this was my first-time-DIY and that the measures are not 100% optimized.
jens |
#5 |
Hi Will,
hope you read the rest of the thread as well as I just realize you might have overlooked the error in post4. 0.492in is the radius of the port, not the diameter. See attached pic in post48. BTW: Even for a small room and low SPL Iīd consider a design like the ELF1.5 much more than this pipe which is perfect for nearfield. But thatīs only my opinion.
jens |
| have any w3-871s for sale ? | norman bates | Swap Meet | 0 | 28th October 2008 10:57 AM |
| FS Tb-W3-871S Speakers | jleaman | Swap Meet | 6 | 4th June 2006 12:18 PM |
| W3-871S same that W3-871? | matos81 | Full Range | 8 | 20th March 2006 04:35 PM |
| TangBand W3-871S | Jye | Multi-Way | 47 | 27th July 2004 06:07 AM |
| TB w3-871s and low x-max | markp | Multi-Way | 14 | 25th May 2004 11:26 PM |
| Page generated in 0.08219 seconds (76.21% PHP - 23.79% MySQL) with 10 queries |
