Old 11th January 2005, 06:36 PM   #1
rv1890 is offline rv1890  Armenia
Default adjustable crossover
I have noticed that all of the 3 way adjustable electronic crossovers that are available on the market require a tri amped system. One amp for the sub, one for the mid, and one for the tweeter. Does anyone know of a 3 way electronic adjustable crossover such as the Behringer CX3400, but one that only requires a single ampilifier for the input. I am newbie and maybe I am asking the wrong question, but I cant seem to find an answer or someone to correct me.
I have a tower speaker system with one 8 inch sub, 5-1/4" mid, and a 1 inch tweeter. Instead of making a standard 3 way crossover, I would like to incorporate a 3 way electronic one that is adjustable but only requires one amplifier to drive it......ANy help....(anything close would be appreciated also).....Thanks
Old 11th January 2005, 07:37 PM   #2
just another
wintermute's Avatar
You could use one amplifier but it would have to be a six chanel one! when you split with an active crossover you do it before amplification takes place, not after, therefore you need a discrete amplifier for each driver in your speakers.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th January 2005, 10:03 PM   #3
awboy is offline awboy  Netherlands
Default Re: adjustable crossover
These active or electronic crossovers are desiged to be put between the stereo source and the poweramps.
The input should be a low level signal like that coming from the cd/dvd/tuner player or a rca recording output of a amplifier.
The crossover divides the lowlevel stereo input into 6 lowlevel outputs (left sub,left mid, left high, right sub, right mid and right high) which all need to be amplified by a power amplifier to drive the loudspeaker it is going to (sub left, mid left, tweeter left ... etc).
You should not try to connect the amplifier poweroutput to the Behringer input!
The 6 outputs of the Behringer should be connected to six power amplifier channels.
You could use 3 stereo amplifiers, or use a modern avr receiver with at least 6.1 power output channels and a 6.1 low level analog input like the denon 2105 and up, yamaha 650 and up, pioneer 814 and up, and many more.
There are also 6-channel power amps but mostly too expensive (however, if you got the money for a Behringer this might not be a problem at all).
adjustable inductor in SP1/2E crossover spendorspain Multi-Way 11 26th January 2008 04:20 PM
4 Sale: Vintage JBL L40 Adjustable Crossover "Pair" (2 way) Minion Swap Meet 3 22nd January 2007 05:41 PM
crossover software - adjustable while listening to a song jaygeorge1979 Multi-Way 32 5th January 2006 06:18 AM
adjustable resistor or potentiometer choise to use in a crossover maya1 Multi-Way 1 2nd May 2004 02:41 PM
Adjustable Infinite Slope Crossover Rarkov Solid State 1 22nd September 2002 07:02 PM
Page generated in 0.07596 seconds (77.76% PHP - 22.24% MySQL) with 10 queries
