Old 11th January 2005, 12:01 PM   #1
Default Linkwitz tries the Pareto rule
Linkwitz Orion - six months pregnant?
News of a "baby brother" to the Linkwitz Orion from SL’s site:
PLUTO
“In Spring of 2005 I will describe on this website a new loudspeaker for DIY construction. It is targeted for smaller listening spaces and for lower budgets than would be required for the ORION. The speaker will be easy to build from readily available hardware. Each unit will have a built-in crossover/equalizer and two power amplifiers. I will provide printed circuit boards and construction plans.
PLUTO is omni-directional over most of its frequency range, because the two drivers are mounted at the ends of tubes. This type of enclosure provides path length to absorb the rear wave from the driver's cone and it eliminates secondary radiation of sound from the tubular walls due to their extreme stiffness. The crossover frequency is at a low 1 kHz.
In my listening tests PLUTO stands up respectably to the ORION. It delivers a highly satisfying musical experience. Overall I would estimate that it reaches 80% of the sonic performance of an ORION, yet it accomplishes that at only 20% of its cost. With built-in amplification PLUTO is well suited for multi-channel surround setups, or to be driven from portable music devices and computers.”
(Not very clear) photo at bottom of http://www.linkwitzlab.com/
omni, not dipole it seems
Only about three months away . .
Old 11th January 2005, 12:13 PM   #2
john k...'s Avatar
(JPK) This has already been the topic of some emotional debate at MAD. Frankly, if anyone other than SL posted a design like this and made the performance claims SL is making, he would be laughed off the board. Since SL posted it I guess it will end up causing a run on Home Depot and a shortage of PVC pipe. Of course, if you prefer black you can go with the ABS option.
As I said at MAD, does Pluto refer to the planet or the cartoon character?
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 11th January 2005, 02:52 PM   #3
Zaph is offline Zaph  United States
Zaph's Avatar
Well, I just hope that top driver in the picture isn't the Aura NSW2. It has a ragged response, high linear distortion at 2kHz, and a severely drooping top octave. All of that was clearly audible in casual music listening.
Check out the mountain ridge in the CSD at 2kHz:
-Zaph|Audio-
Old 11th January 2005, 02:59 PM   #4
Not sure why the noise on this Pluto design. Just like any other
loudspeaker design, you will either like the sound or not, then
life goes on
Old 11th January 2005, 03:24 PM   #5
jmikes is offline jmikes  Canada
Since it dares go against the cumulative wisdom of so many speaker experts here and -- especially -- at the Madisound board, most of whom insist that the only good sound is narrow angle sound beamed at you from a narrowly defined soundstage, I suspect it will receive its share of snotty reviews. Those of us with open minds and ears will take it on its own merits.
Old 11th January 2005, 03:52 PM   #6
Davey is offline Davey  United States
John,
The snide remarks don't become you.
You and SL are two of the very few folks (in my book) who would earn a benefit-of-the-doubt on a new design. I would think it's prudent for everyone to withhold critisism until more information is known.
Davey.
Old 11th January 2005, 04:33 PM   #7
john k...'s Avatar
Originally posted by Davey
John,
Davey.
(JPK) I'll role with the punch and take the compliment Davey, even though I seem at odds with you on this one. By the way, I like your "econOpole" system with the CA18 mids.
The problem I have with the Pluto is it just isn''t anything even remotely close to new or inovative. Designs like this have been around since the 60's. And frankly SL's hype, "80% of the Orion for 20% of the cost. " Well, we all know the limitations of a 2-way with a 5" woofer, so what does that say about the Orion?
Old 11th January 2005, 05:46 PM   #8
amt is offline amt  United States
Could it be a three driver two-way with a long-throw 5" at either end of the tube and connected out of phase, to be a dipole or maybe bipole/ in phase? Equalized and powered by LM3886s with a tweeter over 1k? If this was covered at MAD, sorry. I find that forum so slow to load that I have given up looking at it.
amt
Old 11th January 2005, 06:42 PM   #9
5th element's Avatar
It either says the orion is not up to much, or the pluto is one heck of a speaker. I have nothing to support the pluto being brilliant but id rather swing for the latter.
We all know the orion is a good speaker, top class drive units with a well implemented crossover and rave reviews from everyone who listens to them.
These are Linkwitz words describing a Linkwitz speaker so its bound to be good stuff he says about them.
But we will have to wait and see. Xover at 1khz, hmm he seems to push tweeters more and more everytime he uses one. I can see a scan 97 going down to 1k, its flat on my baffle to 500hz, but only at limited SPL because it would reach the end of its xmax fairly quickly. However a 5" midbass cannot produce much on its own anyway with respect to SPL.
Again we shall have to wait and see.
Next time I go to my DIY store ill by some PVC pipe then and throw some audax AP100ZO's in them and see what happens using the KX drivers as an xover. Watch this space!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 11th January 2005, 06:43 PM   #10
I tried to read the thread, but the site is so slow I figure it must run on an AT and DOS 1.2. As far as I could tell, the gist of it is that some object to SL satisfying his own curiosity with an experiment. Not dipole? Horrors!!!!!
Pretty humorous, actually. A couple of guys who couldn't carry Linkwitz' resume getting snippy about his projects.
The Golden Rule? jered22 Full Range 18 21st February 2012 10:26 PM
One rib to rule them all - PMS greenie512 Multi-Way 19 13th January 2009 11:01 PM
Golden Rule???? Higo Multi-Way 5 14th March 2002 12:57 AM
Page generated in 0.13058 seconds (78.81% PHP - 21.19% MySQL) with 10 queries
