Old 11th January 2005, 05:36 AM   #1
paulspencer's Avatar
Thumbs down First try at active is a dud :(
I have built a 4LR 3 way active xo and was surprised to find that it hasn't worked very well
My speakers:
Vifa MTM TLs built from a kit with a 2.5 way passive xo (I think it could be improved with poly caps in place of electrolytic and possibly a lower xo point but they do sound good as they are)
Subs - 2 x Stryke AV12 currently placed to the side of the mains
Active xo:
4LR 3 way @ 80 Hz & 2.4k
Amps:
Tweeter: using a little mini system (unfortunately it goes through another preamp here) >>> to be replaced with my chip amp when I get rid of the hum
Mid: my trusty old Akai, a relaxed sounding amp
Sub: beefy Behringer EP2500
I'm also using Ultracurve to eq the whole thing flat. The problem is, it doesn't sound flat! The treble is in my face and the bass is weak sounding! It makes me wonder if the mic isn't happy with the 15V its getting from the phantom power from ultracurve. I tried to measure the voltage but it seemed to be very low.
Suggestions anyone as to where to go from here?
I don't have BSC on my active xo or anything more than dividing up the frequencies. I had hoped that Ultracurve would in fact do the trick. Should I start looking into making the active xo a bit more sophisticated? Are there other functions I should add to my active xo?
I'm thinking first I need to at least get it to actually sound flat!
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 11th January 2005, 05:47 AM   #2
simon5 is offline simon5  Canada
I think you should crosscheck your measurements with a SPL meter, maybe your mic failed, I don't know.
Did you remove all the passive crossover network? Yes, I guess.
Maybe your little mini system is going into distortion so you get the in your face sound?
Good luck!
DIYaudio for President !
Old 11th January 2005, 05:47 AM   #3
Bill Fitzpatrick's Avatar
You did say you removed the passive crossover from your 2 way, didn't you?
Each of your amps has a volume control, right? Or at least the tweet and mid amp do, right?
Another possibility is that you wired the active crossover wrong.
Old 11th January 2005, 06:12 AM   #4
If your passive corossover was second order, the tweeter will have been wired out-of-phase with the mids.
Check the polarity of each of your drivers.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 11th January 2005, 06:35 AM   #5
For interest, this is what Ultracurve is doing to supposedly get this thing flat:
Old 11th January 2005, 06:36 AM   #6
Another issue with filter orders:
If you have a 4th order LPF in front of the subs and a 4th order HPF in front of the mains then the signals won't add in phase, due to your main speakers' intrinsic highpass function.
You will need a HPF (of lower order than 4) in front of your mains, dimensioned such that it's response adds up (together with the speaker's intrinsic higpass response) to the desired 4th order highpass function @ 80 Hz.
If such things are sorted out than nothing will stop you from getting into "HiFi heaven".
Charles
Old 11th January 2005, 06:43 AM   #7
Oh no, not another thing to buy!!! :O
Yes I did remove the passive xo from both speakers. I put in some passive protection, thrown together quick which consists of a 2nd order HP to the tweeter at 800 Hz, which is 1.5 octaves below the xo point.
The tweeter amp has a volume control as does the sub, the latter being on full, the tweeter turned back a little. The mid doesn't have a volume control. I fiddled with the trim pots on the active xo but there was a lot of turning and not much difference. For a quick test I was hoping ultracurve could compensate enough, using its AutoEQ function - it puts out noise, shows the response and sets about eq'ing til its perfectly flat at the listening position.
Hmmmm I never wired the tweeter up like that anyway. If it was done wrong, what would I expect subjectively?
I was careful to get the polarity correct, nothing is reversed. I'm very careful about that stuff.
Apparently I'm supposed to set the gain of the active xo with the trim pots using an oscilloscope which I don't have, but I have downloaded software scopes. Will that work? Anyone know anything about how to do this?
Old 11th January 2005, 06:45 AM   #8
G'day Paul
You were posting while I was still typing.
The peak that the Behringer's EQ uses at 60 Hz in order to achieve a flat response could either be due to a room mode or the effect that I mentioned before.
Maybe you could make a provisional (i.e. quick and dirty) try and tap your highpass after the first 2nd order section of your 4th order LR highpass and look how things change. While this would not be an exact approach it might show some tendencies.
Charles
Old 11th January 2005, 07:00 AM   #9
Remove the "passive protection" as you call it. It's part of your problem. If you need protection, stick in a n.p. electrolytic of about 100mfd until you get things squared away.
Old 11th January 2005, 08:04 AM   #10
Charles, my head is spinning at the moment trying to suss all of that out. I have always paid little attention to that phase stuff!
My mains are tuned at about 40 Hz but I'm crossing at 80 Hz. Hence if I used a 2nd order filter, wouldn't it be worse? Unless I was crossing at 40 Hz, but I dont' want to cross that low. I don't see how I can achieve this. What is the nature of the phase effect here due to the rolloff at 40 Hz?
I think I'm in need of a little more elaboration here ...
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Component Suggestion: 2-way active now, 3-way active later CanadianDream Multi-Way 6 3rd August 2007 04:53 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
Active 3 Way vs Active 2.1: Too many alignments and too may questions. goldyrathore Multi-Way 1 22nd April 2005 02:42 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.12721 seconds (81.43% PHP - 18.57% MySQL) with 11 queries
