Old 10th January 2005, 11:34 AM   #1
led_zeppelin's Avatar
Default Active xo question
Just a quick one, looking at this balanced input circuit
Balanced Input
leading to an active crossover, if i wanted to add an un-balanced input, could i just input it directly at the output of the first op amp (would also be unbalanced line out from the balanced line in?) or should it have another input op amp, connected to the same place (before the 10k to the second opamp)
Cheers for your help.
DIY, The only way to do it.
Old 10th January 2005, 02:10 PM   #2
Davey is offline Davey  United States
For unbalanced operation just use one of the inputs and ground the other. You don't need to modify or add any additional circuitry.
Davey.
active speaker question(s) Tristanc1 Multi-Way 0 5th October 2006 05:05 PM
active x-over question. fazman Multi-Way 7 14th July 2006 08:43 PM
Active filter question youyoung21147 Parts 3 21st May 2006 05:27 PM
Active x/o upgrade question Minds Car Audio 8 4th April 2006 04:55 PM
question on active crossovers ogp Everything Else 7 2nd November 2001 12:21 PM
Page generated in 0.07082 seconds (67.26% PHP - 32.74% MySQL) with 10 queries
