I've got a few (6) Vifa PL18WO17-04 drivers laying around (partexpress blowout) And couldn't help but notice they're nearly the same as the 8 ohm drivers specified for the Eros. I would couple it to the very same Scan Speak 2905/9500 tweeter.
I know Wayne did a lot of work figureing out that crossover, and I'm a little lost in that respect. His crossover design isn't a normal one, so it isn't possible to reverse engineer it, and change the crossover values (or is it?) Any thoughts on a crossover schematic? Advice on points, slopes, and schematics would be greatly appreciated
#2 |
hey dude sell me a pair of those PL's.
#3 |
well, if anyone ever helps me out
Come on people, I know somebody has to have some input. You were all in my position once... |
#4 |
I built the eros cabinet with p/express vifa buyout: 2 4ohms wired in parallel. Wire two drivers in parallel instead of one in the schematic, attached. Final impedance is close to 4 ohms.Easy to drive but you need an amp that will drive 4 ohms. Leave a seperate compartment for xo at the bottom and make sure cables are long enough so you can tweak the xo for final response.Trust your ears.Built xo on a board, particle board etc
L2 1mH L1 0.15 mH R1 around 5 ohm, tweak this for your tweeter may be less if your tweeter's sensitivity is less than xt, but don't go too low(3-4 ohm) C1:27 uf(tweak up or down first until the image of drivers blend. C3:7uf(adjust up or down a little to suit your taste) I didn't need the rc shunt across the woofers. It sounded the same so I did away with it. Adjust one at a time. First R1 to tame your tweeter. Then C1 and C2, the inductors are fine. Buy low dcr ones. Then start listenning for a long time(weeks,months!) for final minor adjustments |
#5 |
I kind of want it to be an 8 ohm speaker. I've got a start on a crossover design, but it needs some proofreading.
The Scan speak 2905/9500 is 8 ohms with a sensativity of 90db A pair of 4 ohm PL18's in series is 8 ohms with a sensativity of 90db (add 3db for two drivers, correct?) Since the sensativity of the mids and the tweet are the same, it will make things a lot easier. Here's what I have so far: now, I will still need a Zoble on the mids, but I wasn't sure how to calculate a Zoble circuit for two mids. It seems the Pl18s have a L1 of .61 mh, so if you double that and plug it into the formula, it looks like I'll need a capacitor of 19.0 uF |
| Eros loudspeaker | potepuh | Swap Meet | 0 | 23rd April 2006 07:55 PM |
| Eros Tweeter?! | Wyloch | Multi-Way | 2 | 6th June 2005 12:31 AM |
| Eros with different crossovers. | rs1026 | Multi-Way | 7 | 9th December 2004 05:31 PM |
| Eros | bhg41088 | Multi-Way | 1 | 16th August 2004 12:48 AM |
| Anyone here build the VSS Eros? | jwv3 | Multi-Way | 4 | 18th March 2002 10:31 PM |
| Page generated in 0.08875 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
