I am looking at the possibility of bi-amping without using electronic crossovers. Would it be okay if I build a passive crossover and insert it before the power amplifiers? After all, even active crossovers are a series of filters!
#2 |
You would be much better off using an active crossover, or putting the passive crossover components in the amp enclosure on the outputs.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 | |
#4 |
If I build a passive crossover using the same specifications as per the original speakers, I suppose I do not have to tweak it as the original componets were chosen with the box design in mind eg. roll-off, Xover freq etc.
The reason I want to do it this way is to split the signal before amplification as is done by electronic crossovers. This is to allow specific power amps to amplify certain frequency range only to optimize the full benefits of bi-amping.
#5 | ||
You can use a passive line-level crossover. I believe there has been quite a bit of discussion about them here before. I would recommend using an active crossover though; they have many desirable characteristics.
http://mrevil.pwp.blueyonder.co.uk/ |
#6 |
That and what are you going to do about the very large value inductors you will be needing?
#7 | |
#8 | ||
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#9 |
Passive line-level crossovers are possible, but fairly difficult to implement in most cases. Inductor values increase dramatically, but it is still possible. The impedances involved are fairly low and a stout preamp (maybe a headphone amp) would be required.Check the Marchand XM46 crossover:
http://www.marchandelec.com/xm46.html Passive crossovers using RC circuits (vice LC circuits) are possible, but there can be significant insertion loss, Q's are limited to 0.5 maximum, slopes are realistically limited to second-order, etc. Interconnect driving ability may also be a factor. There are many variables, but if the proper combination of preamp, power-amps, and a not too challenging topology is required then passive line-level crossovers are a viable alternative. Active crossovers solve a multitude of problems and are preferred in most cases. ![]() Cheers, Davey. |
#10 |
There is nothing wrong with using a PLLXO but you then have to involve the input impedance of the next thing in line after the PLLXO, and include the article driving the PLLXO. You can think about a PLLXO like a normal loudspeaker.
Power amplifier drives the coils, caps and resistors, and the loudpeaker drive units. The coils, caps and resistors are designed around the loudspeakers impedance curve and frequency response to achieve a desired result. In a PLLXO the preamp drives the coils, caps and resistors, and the power amplifier input impedance. You design caps, coils and resistors in the PLLXO around the input impedance of the power amp and the drive units frequency response. The benafit this brings is the usual coupling of the power amp directly to the loudspeakers, and xover designed around a fixed impedance that doesnt change with level. The power amp input impedance doesnt change with frequency or how many watts the amp is giving out. Loudspeaker voice coils impedance vary with frequency and increases when power is applied. The versatility of a PLXXO is not as much as a real active xover and is harder to implement. If you want to do xover before amplifier then just throw a few opamps in the circuit too, this removes the need for large inductors (because of the power amp high input impedance) and pretty much removes the preamp having to be capable of driving a difficult load. www.linkwitzlab.com has some useful info on active xovers.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
| Bi amping | adventfan | Solid State | 14 | 26th June 2008 04:28 PM |
| Bi-Amping.....Which one where? | THUMP LUMP | Solid State | 3 | 17th December 2007 09:24 PM |
| Bi-amping | keyser | Multi-Way | 2 | 10th February 2005 12:57 PM |
| Tri amping SOZ | Magura | Pass Labs | 6 | 8th January 2004 09:51 PM |
| Bi-amping set up? | MikeW | Pass Labs | 8 | 13th November 2003 03:27 AM |
| Page generated in 0.12732 seconds (81.46% PHP - 18.54% MySQL) with 10 queries |
