what to pair with magnepan tweeter?
Old 9th January 2005, 05:12 AM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default what to pair with magnepan tweeter?
hey guys. i had an unfortunate accident the other night that ultimately fried both my tweeters on my magnepan tympani 1D's. i have new tweeters being shipped as we speak.
my old ones "work" they just buzz when they get loud (80+dB?). they are fine for quiet listening and really only buzz when they are doing female vocals very loud. other than that you would think they are fine. problem is, my room is BIG, so i need to play them loud.
SO, i am removing those and putting in the new ones. they are crossed over a 1khz in the speaker, so they have a pretty big range. the question is, if i want to use these for a bedroom speaker what would/could i pair with it? the bedroom is pretty small (maybe 12 x 15?). so, they dont need to go loud at ALL.
i would just hate to throw them away when they really work OK. since i am saving up to buy my milling machine, money is about as tight as it can be. i have a 3-channel gainclone that i will use to power it (might even built a 4th channel and bi-amp with it). i would like it to go relatively low, but nothing spectacular. i saw these on apex jr.'s website:
(first speaker on page)
http://www.apexjr.com/speakerstuff.html
Cerwin-Vega 6" 16 ohm woofer good for MTM system $5.00ea.
would a pair of those per channel be decent? cross them over at 1khz, add a cheap xover and be done?
im just dumb with speakers, so i kinda need to be told what to get. could a simple 6" - 8" driver work? i saw some cheap dayton 8" bass drivers in partsexpress that were like $20 each.
any help would be great. all i know about the drivers is that they are the older planar-magnetics, go up to around 22khz and supposedly are crossed over at 1khz. they are like 4-6 ohm too.
Old 9th January 2005, 06:46 PM   #2
cowanrg's Avatar
bump?
Old 11th January 2005, 04:57 AM   #3
cowanrg's Avatar
anyone???
is this a really dumb or really hard question?
Old 11th January 2005, 06:38 AM   #4
simon5 is offline simon5  Canada
I guess the Cerwin Vega is better suited to your project and it's also cheaper, don't invest too much money in a broken tweeter IMO.
If you want some bass, then get the Dayton 8".
DIYaudio for President !
Old 11th January 2005, 06:42 AM   #5
Jocko Homo is offline Jocko Homo  United States
Banned
I would be more interested in taking them apart, finding out what fried, and why, and if there is any chance of making it better.
Sounds like more fun to mess with them. Better to experiment on semi-defective ones, than to take a new set apart.
Jocko
Old 11th January 2005, 07:31 AM   #6
amt is offline amt  United States
Buy 32 NSBs from PE for $15 and build an array. Youve got tweeters to die for, for such a project. Easy to clone drive too.
amt
Old 11th January 2005, 09:05 PM   #7
cowanrg's Avatar
i was thinking about the NSB thing, but i was just curious if i could get any bass from them?
i know it sounds wierd to mess with broken tweeters, but i honestly dont think i would ever play them loud enough to make them buzz in the bedroom... but i do plan on trying to take them apart to fix them. the problem is supposedly a loose wire that can be easily re-glued. but, getting them apart is a task.
ive always wanted to use those NSB speakers though, and have a line array. if they could do reasonable bass, i would be interested in them. would you just do an open baffle line array? (the tweeter is di-pole).
Old 12th January 2005, 01:38 AM   #8
Open baffle would be easy and work well with the Maggie tweeter, but you will get next to no bass out of it. I played with a ported box with them on winISD, 16 per side (Ive got 45 of them ) and although not ideal, you can get down to the mid 60s. Add a small sub later.If you arent going to play them loudly, that might be fine. You could also use the tweeter as a monopole and be able to put the speakers up against the wall for some boost. Biamping is going to be best since the array would be 96db efficient and the tweeter in the 80s.
Another option might be to find a pair of used midfi speakers at Goodwill etc, with 10" or12" woofers and remove the other drivers, seal up the holes, and build a Newform style speaker. Easy and cheap.
One last idea would be to pick-up a pair of old Maggies. Ive got two pair of MGIs that Im rebuilding. One pair was free, and the other $50. Both have fixable bass sections but the tweeters are of course shot. Find a pair with blow tweeters and use your tweeter. Although a GC would be a bare minimum power source.
amt
Old 12th January 2005, 03:11 AM   #9
cowanrg's Avatar
hum, interesting thoughts...
im not really into buying a pair of maggies (i probably could find some locally, but its unlikely).
i really just want to use the tweeters i have. i already have a full magnepan theater downstairs. plus, my bedroom is small, and i really wouldnt have room for a full panel maggie. the tweeter panel i have is from a tympani, so its as big as an MMG almost just for the tweeter...
i think building a speaker that looked like the newforms would be cool. just a bass/midrange box at the bottom and a tweeter at the top in an open baffle would be nice. i have ruled out the NSB's becuase they have dont have the bass. i would HAVE to use a sub. 60-70hz just isnt low enough for me to play and enjoy music on. i would be much happier to hit 45hz or so.
the tweeters will have their own gainclone and whatever other drivers will have their own as well. so, if i do like 2 8" daytons, i will have 3 channels of amplification on each speaker. i have some extra boards for my gainclones and extra parts, so building amps would be very cheap.
ultimately, im trying to keep this whole project under $200 TOTAL. MDF is cheap, a few drivers could be cheap, and certainly i can get xover components for cheap too. i have a cd player, and i would do like a passive pre-amp. this is a BUDGET system.
also, would those cerwin vegas be a good thing to look at too? do you think they could go lower than the NSB's? do i need a 3-way, or can a simple 2-way work just fine for getting down to 45hz? thanks guys!
Old 12th January 2005, 05:07 AM   #10
I would forget the CVs since they dont have any t/s info. I think that if you want some decent LF, and simpicity, go with a good 10' or 12" driver that will get you up to up to 2k or so and build a BR box that can mate to your tweeters. You need to really know what the stock xo frequency is and then pick a woofer. If you dont like the results, you will at least have some nice woofers and cabinets to use for something else. Multiple 6"-8" close-outs will create alot more places for error.
amt
what to pair with magnepan tweeter?Hide this!Advertise here!
A pair Seas 4 ohm tweeter used by B&O gaborbela Swap Meet 4 10th December 2012 03:10 PM
Reparing Magnepan SMGs tweeter stolbovoy Planars & Exotics 4 23rd December 2007 03:13 AM
magnepan tweeter transplant Ang Planars & Exotics 11 25th May 2007 02:39 AM
Magnepan ribbon tweeter repair... mcelaj Planars & Exotics 2 17th May 2005 02:15 AM
