Need formula for contour network!!  Anybody?
Old 8th January 2005, 08:50 PM   #1
sardonx is offline sardonx  Canada
Default Need formula for contour network!! Anybody?
I need to design a contour network for a woofer and have been desperately looking for a formula. I found one at www.lalena.com but he is not sure if it's correct. Any information would be great..
sardonx
The End
Old 9th January 2005, 01:06 AM   #2
dooper is offline dooper  Canada
Loudspeaker Design Cookbook by Vance Dickason - I have the sixth edition from 2000. Beginning at p. 147, there are descriptions of circuits for:
situations where:
a) the response is rising with increasing frequency, and
b) the response is rising with decreasing frequency.
For situation a), a parallel RL circuit is used, and for situation b), a parallel RC circuit is used. Which network do you need the formulas for?
dooper
Old 9th January 2005, 02:09 AM   #3
Dooper,
I'm interested in situation A. It's for the SS 7 inch revelator.
The response starts to rise at 800hz and tops out at 1800 with a total rise of about 4db.
The End
Old 9th January 2005, 03:11 AM   #4
1. L (in henries) = 0.15916 / f - in this case f = 400 Hz.
2. "R is selected so the combined impedance of the total circuit equals the amount of maximum-needed attenuation (or average if the rise is not well-defined), where:
Z = (RX) / ((R ^ 2 + X ^ 2) ^ 0.5)
Z = total circuit impedance
X = component reactance at frequency of maximum attenuation"
For an inductor, X = 2 * pi * F * L.
Dickason suggests R = 5 ohms would result in 4.8 dB attenuation.
The book has more info, formulas, and examples. It's well worth the money
EDIT: The formulas on the Web page you posted appear to be the same as the ones in Dickason's LDC.
dooper
Old 9th January 2005, 02:41 PM   #5
Paul W is offline Paul W  United States
Paul W's Avatar
Sardonx,
I used the 7" revelator in my previous system and as I recall, for the circuit you are asking about, L was .2 and R 2-3 ohms. I am not certain about either value...optimum reponse on your baffle may require different values anyhow.
I also used a very subtle series RLC trap across the VC tuned to the ~800Hz impedance glitch in the rev. I don't remember those values at all, but the overall result of the two networks was much flatter reponse. You're on the right track...keep going.
Paul
4-way dipoles
Old 9th January 2005, 09:27 PM   #6
Thang you v much guys.
Paul,
I came up with the same value of L too. As for the resistor I will experiment with it.
I still haven't ordered the revelators but i know they will sound good. Slit paper rules.
sardonx
The End
Need formula for contour network!!  Anybody?Hide this!Advertise here!
DYNAUDIO Contour 4 X-over ekaerin Multi-Way 1 2nd February 2008 12:31 AM
Dynaudio Contour failure. Ducataudio Multi-Way 16 3rd May 2007 11:02 PM
150 HZ Tractrix contour kartsmart Full Range 2 21st September 2005 03:06 AM
Help needed, Contour 1.3mk2 eradoncic Multi-Way 9 27th March 2005 06:13 PM
Dynaudio Contour II Mk2 tuning barni Multi-Way 0 9th September 2003 12:25 PM
