What is the best adhesive for bonding PVC (plumbing) to wood?
#2 |
Interesting question... could you be more specific with how you are using the finished bond?
For example, do you want a liquid adhesive, double-sided tape, UV cured or instant bond? How strong does it have to be? Does it have to be flexible or withstand temperature extremes? Will a mechanical fastener (screws) be sufficient? You can also try any one of 3M's online selector charts. In addition to Threadlocker, Loctite also has excellent adhesives for just about every other purpose. You are in Seattle, if you are near Boeing surplus they may be able to help you. :)ensen.
Those who claim to be making history are often the same ones repeating it. |
#3 |
I've always had very good luck with a nice slow setting 2-part epoxy.
#4 |
It would be PVC tubing connected to the rear of a dipole panel made of either MDF or plywood (haven't decided yet). Its to hold a rear firing tweeter. Basically, I'm making some cosmetic changes to John K.'s NaO. http://www.geocities.com/kreskovs/John1.html
#5 |
So you are putting a PVC tube between the two tweeters... wouldn't that change the dipole effect of the design?
May I suggest that instead you use threaded rods instead of mounting screws for the tweeters. If the tweeter has 4 mounting holes, use 4 rods and 4 x 12mm PVC tubes. The tubes would be the length needed to space the two tweeters apart. Run the bolts/rods from the front tweeter, through the baffle, through the PVC tube through the rear baffle and through the rear tweeter. Tighten the whole thing with a nut on the back and voila... dipoles. :)ensen.
#6 | |
#7 |
#8 | ||
#9 |
If you bond to the baffle, then you can't replace if you burn them.
Yes, router a step in the baffle to flush mount the driver. Then it is typical to drill 4 pilot holes to screw the driver to the baffle. What I suggest is to drill holes as big as the driver mount holes and use ~6" bolts to connect the front and back tweeter. I will post a quick sketch tomorrow from my office. :)ensen.
#10 |
I think we're having a communication problem here. The SEAS (front firing unit) is mounted normally. The back of the plywood panel would have a trough routed for the PVC for extra structural support, and then bonded to it. then the Vifa (rear firing tweeter) would be mounted "normally" on the other end of the PVC tubing via wood (or some such) plug. both units are removable. The bonding is at the one junction between the wood baffle (panel) and PVC tube.
| Inner detail, as opposed to? | Sheldon | Tubes / Valves | 14 | 22nd January 2008 01:31 AM |
| Anyone know detail about Accuphase MDS Tech?? | fobyellow | Digital Source | 0 | 17th April 2007 06:42 AM |
| detail av-800 | broka | Solid State | 1 | 10th December 2006 12:34 PM |
| SEAS T17RE (823), need detail/review/opinion | piro | Multi-Way | 29 | 4th October 2004 11:04 PM |
| Regulation, GC and low-level detail | Dr.H | Chip Amps | 17 | 5th August 2004 03:58 AM |
| Page generated in 0.09430 seconds (79.53% PHP - 20.47% MySQL) with 11 queries |
