I have an AR PSC25 center channel. I think the tweeter is a Vifa TC26SF05, but cannot tell what the woofer is. Does anyone have that info or where to find it?? I couldn't find any info.
I'm thinking of tweaking the factory crossover in hopes of improving imaging and quality of xo. For example the inductor on the xo is a dinky metal core .2mH, which makes the xo around 6kHz at 8ohm if I understand things correctly. any help is appreciated, as i've only read about speaker stuff till now thanks |
#2 |
any numbers on the back of the woofer?
Also, what size is it? |
#3 |
there are numbers on the back, which i can't make sense of
i'll get them tonight 5.25", poly cone, concave dust cap, rubber surround, metal stamp frame, shielded magnet i found one that looked very similar except not shielded it's a peerless at madisound http://www.madisound.com/850234.pdf |
#4 |
the numbers on the back are
D-9910008 054WS looking at the cone again, i don't think it's poly, i think it is paper type material i'm hoping to find fr info so i can use it to tweak, hopefully improve, the stock crossover do you all think it would make any difference? |
| Hungarian speaker identity? | Duo | Multi-Way | 24 | 6th August 2010 01:23 PM |
| Identity of two vintage drivers? | Brisso57 | Multi-Way | 3 | 18th November 2008 03:42 AM |
| Choke identity | mashaffer | Tubes / Valves | 1 | 13th July 2004 01:50 PM |
| Driver identity? | MMBRacing | Multi-Way | 1 | 25th January 2004 11:32 AM |
| Page generated in 0.06541 seconds (74.42% PHP - 25.58% MySQL) with 10 queries |
