Are there any particular resistors to avoid in passive crossovers? Wirewound cement resistors seem suitable to me but I am worried abut the inductance associated with them. Are their inductance significantly high? Any other concerns about resistor selection? Thanks, Murat |
#2 |
HEEEELP!
I will order parts soon. |
#3 |
Why not play it safe and use metal oxide resistors? They're only a dollar each at madisound. Worth the piece of mind....
javascript:smilie(' ')angel www.gattiweb.com |
#4 |
just another
The other thing is that most wirewound resistors are available in non-inductive versions. No matter what you choose you would be best to check that they are non-inductive types.
Tony. |
| replacement resistors for esl57 crossover | Audiofool | Planars & Exotics | 16 | 16th September 2011 02:19 PM |
| Crossover Resistors.. Advice Needed | gilbert- | Multi-Way | 2 | 1st June 2006 01:25 PM |
| parallel resistors / capacitors in crossover | jimbo1968 | Parts | 4 | 26th January 2006 05:16 PM |
| crossover question about resistors? | scooby1 | Multi-Way | 2 | 6th September 2005 05:13 AM |
| Crossover resistors | float | Multi-Way | 13 | 9th August 2005 06:07 PM |
| Page generated in 0.06696 seconds (82.59% PHP - 17.41% MySQL) with 10 queries |
