#11 |
Brill, perfect not quite as good as range as parts express but i think they have what i want.
Does anyone have any idea what the sub cross over frequency is for the sony a/v reciever (link above)? Will the simple vented box be alright or should i be thinking of more complex designs? |
#12 | |
Considering your price range and goals a BR box should work well. |
#13 |
Ok Dannyball that makes it a bit easier
If you can make a sealed box with a f-3 that matches the amps xo then you'd do well. AV receivers generally roll of the main speakers at 12dB/octave, and the sub at 24dB/octave. Sealed boxes roll of around 12dB octave and added to the receivers roll off would produce a 24dB slope to match the sub. Hope that makes sense. Good luck with your project btw. Try maplins or bkelectronics for some more driver choice: www.maplin.co.uk http://www.bkelec.com/new/ I take it you found wilmslow aswell: http://www.wilmslow-audio.co.uk/ Cheers, Rob EDIT: maybe a pro 10" driver plus tweet would work well for this app ? - or even a 10" full range in a sealed box.... |
#14 | |
#15 |
I'm trying to keep the boxes as small as poosible as my room is not all that big. Will a 6" do in a sealed enclosure plus a tweeter.
This is what i had in mind: http://www.maplin.co.uk/Module.aspx?...ldID=6&doy=7m1 |
#16 |
This is a quick sim of the Alpha 6 in WinISD just to give you a comparison.
#17 |
Sorry, i feel a bit stupid asking this but what is the graph showing?
#18 |
I am also currently looking to build some speakers for my home cinema system, and being based inthe UK have found that drivers are alot more expensive than they are in the US.
Have you had a look at the Alcone units available from www.bkelec.com? (UK based) The prices are very reasonable, the AC 5.25 HE is just £25.00 and the AC 6.5 He is £32.00. For and example of what you can acheive with these take a look at this web page; http://www.lautsprechershop.de/hifi/index_en.htm, it maybe in german but you can get a good idea!
#19 |
Hey Tim,
Maybe if you ported the alpha 6 @40Hz-ish the curve would resemble a sealed roll off with a lower f3 ? A bit like an ebs curve. Cheers, Rob The graphs are showing simulated output in dB against frequency of your alpha 6 in a sealed box and a ported box. Do a search for winISD and download it and play with it if you haven't got it already. Have a look at this site too: http://ldsg.snippets.org/idx.php3 |
#20 | |
Good call. My post is just a teaser for the Dball man. ![]() Dannyball, WinISD Alpha is a good place to start playing around with T/S parameters and frequency response sims. It is not comprehensive but it can get you going in the right direction, especially with cabinet size and ported vs. sealed. Crossover design is another animal completely. There are freeware programs for that too but the only way to do it correctly is to perform reasonably accurate measurements with programs like JustMLS or Praxis, then import those measurements into a crossover simulation program like LspCAD. Even then you may need to tweak the XO to get it right. |
| Crossover Advice for Home Cinema DIY | RedCoat23 | Multi-Way | 10 | 7th July 2008 12:29 AM |
| Active Crossover and 7.1 Home Cinema Amp | mikethomas79 | Multi-Way | 4 | 28th February 2008 01:53 PM |
| home cinema speakers | skogs | Multi-Way | 6 | 7th September 2007 05:15 PM |
| Using Clas D amplifiers for Home Cinema Project ? | philippe_95 | Class D | 4 | 16th November 2006 08:05 AM |
| TV/home cinema speakers | Hay | Introductions | 1 | 6th January 2002 04:50 PM |
