Banned
I have a feeling this may be detrimental to certain sealed box parameters.... lol
any suggestions on fixing it?
#2 |
Nothing that a little duct tape couldn't fix.
#3 |
You're mispronouncing it: It's a "mod."
lol Dave
I have a small website for my projects. |
#4 |
Banned
speaker, meet foot, foot meet speaker..
#5 |
AFAIK, there's nothing you can do that will restore the speaker to "sealed" status without also changing the frequency response, TS params, breakup modes, etc.
If it's possible to get a replacement driver, this is the ideal solution. Failing that... try a lightweight paper stuck on with contact cement. |
#6 |
Your picture is a little too dark, makes the tear seem worse than it is. A little work with XnView freeware, www.xnview.com, to lighten it up and we see that it simply looks like a flap that can be glued on in place. I don't know if this stuff is available in Australia, but it sure is worth looking for. PC-7 and PC-11. Best epoxy you can use-a bit expensive, but a million uses and you will be happy you bought it. Use it sparingly to join the two edges of the flap all around, make sure it is sealed but don't pile it on. Your speaker will be returned to very near the Thiele-Small parameters and response of a brand new cone. PC-7 or PC-11. PC-11 is more expensive, but often sold in marine supply houses-it is just as rock-tough as PC-7, but can be used underwater. I suggest you pay the extra money for PC-11 only if PC-7 is not available at your local hardware stores.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#7 |
It's not a flaw....it's a feature.
If it sounds good... it is good! |
#8 |
looks like an excuse for a new project.
#9 |
I use mylar for repairs on gelcoat & fiberglass. Before everybody gets all huffy, it's only used as a sort of barrier for the epoxy or resin. It peals right off after the material has hardened. You can find it at sign shops in their garbage cans. It has one side that's very shiney and won't stick to anything.
My guess would be that you can sandwich the tear between two pieces after the epoxy is applied. This will alow you to massage and work it into the torn fibers... ever so gently. The mylar will nearly fall off after the material is hardened. I use a little masking tape to hold the mylar in place. |
#10 |
Speakerholic
If I remember correctly, Mylar(TM) is Duponts name for "A sheet of polyester" often sold coated with an oxide.
Does the polyester resin in fiberglass not affect the sheet polyester? I would have thought it might reactivate it. I sure like the method you have, quite ingenious. Me? I just use some watered down yellow (carpenters) glue, smear it on with my fingers and lick off the excess. ![]() Time for a couple new drivers SkinnyBoy? Cal |
| What makes the good guitar pickup sound so good? | darkfenriz | Instruments and Amps | 15 | 1st March 2009 11:46 PM |
| Good switch for Stepped attentuater, Good cheap RCA jacks | pjpoes | Parts | 20 | 10th March 2005 08:47 PM |
| Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? | XteveX | Multi-Way | 7 | 28th April 2004 04:05 AM |
| Page generated in 0.11127 seconds (73.13% PHP - 26.87% MySQL) with 11 queries |
