Hello everyone and HAPPY NEW YEAR!
I'm a newbie to loudspeaker design and this is my very first post, so try to be kind if I sound a bit block-headed! First off, let me tell you about myself and what I'm trying to do. I've been tinkering with electronics for roughly 30 years now, and just recently I've been stricken with the vintage electronics bug. In the past 6 months, Ive fully restored a Scott 222, Sherwood S-5500 and a Dynaco SCA-35. They all sound great but I know I could better sound with better speakers. I've got a pair of EPI T/E 320's that could use a little TLC themselves! Anyway, now it's time to learn about speakers! Here's my first question: The new PartsExpress catalog has a "Speaker Building Guide", and I noticed that the same speaker models with different impedance versions (4 and 8 ohms) require different box volumes. For example, the 12" Goldwood woofer, Model GW-12PC. In a vented volume, the 4 ohm version requires a 2.1 cu. ft. box, while the 8 ohm version requires a 4.55 cu. ft. box. Why is this? TubeHead Johnny. |
#2 |
just another
Welcome to the forum Tubehead Johny
Looking at the specs of the two speakers, it looks like the only difference is due to the different impeadance. The 8 ohm version has higher impeadance and voice coil inductance, which results in a higer Qes, since the Qms is the same for both drivers the Qts changes, hence the difference in the volume required. If that was all over your head then it's time do some reading on thele/small parameters http://editweb.iglou.com/eminence/em...s02/params.htmNote that the PE site says the speakers are designed for small sealed enclosures...... you might want to think twice about doing ported boxes (the Qts of the 8 ohm version is .49 which is over the magic number of .4 which is generally considered the point over which a driver is not suitable for a vented enclosure Tony. |
| Higher impedance = cleaner volume? | JonnySwitchblade | Multi-Way | 8 | 10th July 2007 06:58 PM |
| Aleph P1.7 ladder volume impedance | Has | Pass Labs | 2 | 21st October 2005 08:34 PM |
| BOSOZ--variable impedance volume attenuator | jh6you | Pass Labs | 22 | 15th March 2005 08:34 AM |
| Need enlightments on GainClone input impedance and volume control | Elkaid | Chip Amps | 10 | 8th April 2004 07:35 PM |
| Page generated in 0.24828 seconds (34.11% PHP - 65.89% MySQL) with 10 queries |
