Hi. I'm currently upgrading certain components in the crossover of my Manger 109 speakers. The speaker is a two-way design. The crossover includes three electrolytics: a 220uF lytic in series with an inductor in parallel with the Manger driver, a 267uF lytic in parallel with the bass driver, and a 1000uF lytic in series with an inductor in parallel with the bass driver. Can I remove these capacitors? What function do they perform? Are they DC-block caps, or do they block frequencies below, say, 10 or 15Hz? Appreciate any advice.
Tom |
#3 |
The 220uF electrolyt (parallel to the Manger) is probably used (in conjunction with L1 and R1) to smooth out the impedance at the resonance frequency. I would not upgrade this electrolyt, maybe bypass it was a 4,7 uF MKP. You won't gain much with it.
The 267uF electrolyt is used in the 18db/oct lowpass, you could replace the 47uF with an MKT (or MKP) C3, C4, C5 probably function as a notch filter in conjunction with L3. You could add a bypass MKP, but you won't gain much with this either. |
#4 |
Thanks Bombardon!
Tom |
| Crossover capacitor choice | Jonasa | Multi-Way | 47 | 5th November 2009 11:15 PM |
| Can anyone help me ID this capacitor in crossover? | silentblackhat | Solid State | 10 | 1st November 2008 01:35 AM |
| Crossover capacitor polarity question | rtate | Multi-Way | 2 | 12th August 2008 11:52 AM |
| Capacitor Crossover. Potential Problems | davidbosch | Multi-Way | 5 | 26th January 2008 03:08 PM |
| Capacitor type for crossover | ThSpeakerDude88 | Multi-Way | 23 | 4th August 2007 09:00 AM |
| Page generated in 0.06660 seconds (78.45% PHP - 21.55% MySQL) with 10 queries |
