Old 27th December 2004, 11:42 PM   #1
weddie is offline weddie  United States
Default VIFA P17WJ-00 Ported or Sealed?
Could the VIFA P17WJ-00 driver be placed in a sealed box and have tight bass. If not, could the driver, in a .25 cubic foot box with a 1" diameter port tuned to 50hz, sound terriable? What are the advantages with different port diameters. Would a 1" dia port create more port noise then a 2"? Thanks for you help in advance.
Weddie
P.S. Does anyone have any good designs for a small box with the VIFA P17WJ-00 and is a 3000hz x-over too high?
Old 28th December 2004, 04:33 PM   #2
Davey is offline Davey  United States
It would have tighter bass in a sealed box than a vented box. However, .25 cubic feet is a bit too small for either case.
There are hundreds of DIY designs using this driver available. Google and you will find.
Here's one:
http://www.audiodiycentral.com/sd200_johnk.shtml
Davey.
Old 28th December 2004, 06:12 PM   #3
Pan is offline Pan  Sweden
The P17 in closed box will be almost bassfree. IŽll take reflex bass over no bass any day.10-15 lit. reflexloaded is the deal with that driver IMO.
And yes, a 1" port will be more noisy than a 2"port.
Use as fat port as possible within the capability of the box volume (the wider the port the longer for a fixed tuning).
/Peter
Vifa P17wj and D27 tg series x-over renisnceman Multi-Way 1 16th November 2008 03:29 AM
MTM's using the Vifa P17WJ Nisbeth Multi-Way 12 5th November 2004 03:31 PM
Vifa P17WJ's TL compatible? SteveG Multi-Way 4 19th April 2002 04:03 PM
Page generated in 0.07151 seconds (70.34% PHP - 29.66% MySQL) with 10 queries
