Almost time to start wiring up the line arrays and I still haven't purchased any wire. These speakers house 10 Dayton RS 5" woofers and a single Fountek JP-2.0 ribbon tweeter. The woofers will be wired in four sets, (3,2,Tweeter,2,3) so there will be four sets of + and - going to the woofer binding post. Do you think 16 gauge will do the trick? The runs will be 6 feet at the longest so I can't see why not. Here's what I was going to use:
http://www.partsexpress.com/webpage....ctGroup_ID=475 Thanks! |
#2 |
Sixteen guage should be plenty. My only recommendation is to another color in addition to traditional red & black. That might be used at the terminus of your series runs to parallel connection. That has helped my weak mind.
In my case, I addopted that method after wiring up a tweeter array at 32 ohms. All those wires start looking the same after a while. |
| What's the best wire gauge to run to the HU? | phrarod | Car Audio | 14 | 14th June 2008 12:35 AM |
| inductor wire gauge for line level xover? | poldus | Parts | 0 | 2nd October 2007 04:06 PM |
| which gauge wire for PSU???? | cbutterworth | Tubes / Valves | 6 | 13th December 2006 12:52 PM |
| Chip Amp Wire Gauge | filholder | Chip Amps | 2 | 22nd March 2005 07:04 PM |
| fet wire gauge | MikeZ | Pass Labs | 2 | 21st April 2004 12:43 PM |
| Page generated in 0.06552 seconds (67.72% PHP - 32.28% MySQL) with 10 queries |
