Hey all! I've got a few questions about designing your own crossover networks. For some reason, I just can't find definitive answers searching, or reading on the net, at least, not in the last day or so...
1. When you design a crossover, do you use the Znom ohm, or the Re: Ohm value? For example, the drivers I'm looking at say Znom 8 ohms, but, Re of 6.3 ohms. 2. When adding an L-pad, does one have to compensate for the added resistance? From what I can tell, if you use a L-pad you don't need to worry about this? I don't know why/how this could be. 3. Is there a common rule of thumb for component selection, like, use foil film for the high end, and large gauge air core inductors for the low end? Maybe foil film for the both? 4. As a followup to 3, for low value capacitors, would one recommend more expensive components? Thanks all! |
#2 |
1. use znom,Re is measured at dc
2. you can find the equation for L-pad on the net. the equation is set for the znom of speaker to keep it the same(8ohm will stay 8ohm. If the L-pad is store brought and has the same ohm rating then dont worry about it 3. use foil film for tweeter and midrange use large gauge in- ductor for low end unless,you crossover very low then use iron core. I would not use foil film as bypass cap at low end,its not in path,a lesser cap would do 4. It's really up to you |
#3 |
Hey, thanks for the help!
| Feedback basics | Wavebourn | Tubes / Valves | 33 | 8th October 2006 09:50 PM |
| Help with the basics | keantoken | Everything Else | 3 | 29th September 2006 01:04 AM |
| ESL basics | Urban | Planars & Exotics | 4 | 6th June 2005 05:11 PM |
| DAC basics? | Schaef | Digital Source | 17 | 7th June 2004 06:00 PM |
| Crossover Design Basics | Super | Multi-Way | 10 | 6th July 2001 12:01 AM |
| Page generated in 0.06355 seconds (79.52% PHP - 20.48% MySQL) with 10 queries |
