I'm putting together a cheap center channel speaker using (2) 4x6 automotive speakers in series. I bought the speakers off ebay for $1.65 and the manufacturer states they no longer have the driver specs (?). My searching came up empty except for some other brand 4x6 speaker Thiele-Small parameters (Fs = 117 Hz, Qts = 1.27, Vas = 3.4 L). I've built the enclosure and sized it based on what I need for packaging (it is stacked with the receiver). The cabinet volume is 12 L. I'd like to tinker with porting to enhance the bass a bit. Can I get in the ballpark on a port without the T-S parameters? I'm new to this so any suggestions are welcome. Thanks |
#2 |
Pick a 30mm port and try different lengths, if it sounds better to you (once you find the "right" length) then it is better and good.... or something like that..
![]() /Peter |
#3 |
If you have a specific frequency in mind, and you know how to measure your box's internal volume, you don't need Thiele-small parameters to tune a box to a specific frequency.
If that is what you want to do, simply download the simple version of WinISD, (not Pro). Choose any woofer. Model if for a vented box or bandpass, whichever you prefer. Write in your box volume. Write in your desired tuning frequency. And then go to the "Box" section to see what diameter dn length port works. By any chance, do you have a reliable mic or Radio Shack SPL meter handy? If so, which model number?
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
| Need T/S parameters for SVS ISD driver | mazeroth | Subwoofers | 0 | 24th October 2006 05:16 AM |
| TL vs driver parameters | Henkjan | Full Range | 7 | 21st September 2006 10:24 PM |
| TL design vs driver parameters | Henkjan | Subwoofers | 0 | 20th September 2006 11:03 AM |
| Ported Enclosure Design w/o Driver Theil-Small Parameters | misterbobman | Multi-Way | 6 | 29th March 2005 03:06 PM |
| Sen-Lab Driver TS parameters | jjfox | Multi-Way | 4 | 3rd March 2004 04:54 AM |
| Page generated in 0.08359 seconds (69.64% PHP - 30.36% MySQL) with 10 queries |
