made these (well i still need to finish them) for my sisters wedding present, original inspiration was timn8tr's isa. which i gave up on (too much work.
6.5" wide, 20" tall 6" deep. 3/4" mdf 3 drivers wired in parallel. need to do something about the midrange.... a little much, thinking of trying the BSC from my elf 1.5 and trying it out.... any one have an idea on port size / length? i have the same ports that came with the elf kit. but not sure about length
#2 |
3 in parallel is around 2.7 ohm load, might be hard on whatever amp is going to be used.
What kind of paint or veneer are you going to be using? Also what sub is that on the left, adire? thanks |
#3 | |
Are those dimensions internal or external? The speaker on the left looks like the Adire 81 (AV8 and Audax tweeter). |
#4 |
I'm going to make 3 tb speakers following John Krutke's design. They will be used as front speakrs in a HT settup.
For the rears I want to try something with 2 drivers per box. I want something like those mission rear speakers that radiate in 2 directions. Should I just double the volume and keep the same filter for each driver in the box? sorry for drifting off topic.... |
#5 |
Doubling the volume will work well. The box shape will be different so the filter will have a different effect besides, I think you can do without the filter for surrounds. You'll need to think about whether to wire series or parallel though.
#6 |
what's the main difference between series en parallel?
only the impedance ? or also max spl? |
#7 | ||
#8 | |
You probably meant 2 in parallel, then in series with the third?
jens |
#9 |
Of course I did. I'm "sleep-typing".
I see I got it backwards in my previous post too. Thanks for catching that. |
#10 |
that would present different amounts of power to the drivers...if that matters to you
| Speaker Question (Probably Simple) | TheNewGuy1 | Multi-Way | 5 | 14th July 2009 03:51 AM |
| simple Q about old speaker design | canca87 | Multi-Way | 5 | 1st March 2009 11:58 PM |
| Looking for VERY simple A/B Speaker switch schematic | pitguy3 | Everything Else | 3 | 26th July 2008 07:57 PM |
| Simple Speaker build for dummies | madrugger10 | Multi-Way | 4 | 26th June 2008 12:09 AM |
| simple speaker grill? | gychang | Full Range | 13 | 29th October 2006 12:00 AM |
| Page generated in 0.12808 seconds (65.76% PHP - 34.24% MySQL) with 10 queries |
