diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Pole Piece Q (http://www.diyaudio.com/forums/multi-way/48371-pole-piece.html)
ALFIrE 24th December 2004 05:02 PM
Pole Piece Q
Hi!
I'm building a speaker using the seas L12RCY/P
One of the drivers has an open pole piece "a hole in the back".
The other driver has a white substance in the pole piece, glue I think.
I assume I must open the hole, make it free?
Otherwise, I will blow the driver???
Vikash 24th December 2004 05:27 PM
The driver won't blow if the pole piece vent is blocked. But it should no be blocked for proper operation.
Nappylady 24th December 2004 05:27 PM
Try the driver at low levels. It will probably sound fine. As you inrease the excursion, you might hear some strange sounds--if you do, this means you must remove the white stuff. If you can drive the unit to full linear excursion without it sounding really wrong, then you don't have to remove it.
ALFIrE 24th December 2004 06:09 PM
at a fast first test, one souded fine, the other really distorted... as if the amp was going on and off and cracking all the time...
Resources saved on this page: MySQL 18.75%
