Old 23rd December 2004, 03:29 PM   #1
jmikes is offline jmikes  Canada
Default Budget array project
I bought 20 of these cheapie Pioneer 4-inchers to see if I can't make a semi-decent array. They might be car speakers, from the looks of the mounting flange, which is going to complicate mounting. I'm cutting them at around 4k. For tweets I bought two TB W3-871s to put in the center and run full range. It will be my first array project and I didn't want to spend much in case it's a massive failure.
Comments?
Old 23rd December 2004, 03:58 PM   #2
It shouldn't be a failure unless you give up before you're satisfied.
Use "NSB's" in your search and you'll find lots of info here and elsewhere.
It would be nice to work out a decent mounting arrangement where the drivers are held in place by a slot in the side panels, and save ourselves the trouble of all those holes. It's a pretty odd (or tight) fit.
Be sure to listen OB as you experiment. The 871's are an interesting angle, I'll be interested in hearing how it works out.
onasis
Old 23rd December 2004, 04:15 PM   #3
Banned
You should see if they have any closeout Onkyo tweeters left. Lines work much better if the midbass and tweeters are both line sources rather than one line and one point.
Like this.
Old 23rd December 2004, 04:41 PM   #4
Like this.
Thanks for the tip. They do and I just bought 40.
Old 24th December 2004, 03:05 AM   #5
Default Buyout tweeters
Which Onkyo tweeters would those be? The 3/4" oval shape or the 3/8" round?
Very interested...
Old 24th December 2004, 12:35 PM   #6
Default Re: Buyout tweeters
Very interested...
The .75s.
Budget HT sub project jacsas Subwoofers 1 14th April 2008 03:47 PM
Possible budget line array driver? mpmarino Multi-Way 6 7th May 2007 01:03 AM
Low budget project : T-Amp + ??? hersh Full Range 19 8th June 2006 01:32 PM
Vince's HT as budget project? sqlkev Multi-Way 1 1st February 2005 11:34 PM
noob two-way budget project!! help please? guitar012345678 Multi-Way 1 7th January 2005 07:02 AM
Page generated in 0.08953 seconds (78.17% PHP - 21.83% MySQL) with 10 queries
