Old 19th December 2004, 09:44 PM   #1
Default How high can this popular bass driver be crossed?
The Peerless XLS 12
http://www.d-s-t.com/peerless/data/830500.htm
A very good sub - low distortion, especially for the money.
What more can it do?
The graph shows it’s reasonably flat up to *490 Hz.
I’d like to (because I already have them) mate the XLS actively to a mid, that I thought would go to 180-200 Hz. I now learn that the mid (a PHL) doesn’t like to go below about 280 Hz.
A 4th order at 280 Hz would have the XLS down 24 dB at 560 Hz. From the graph, the sharp dip starting at 490Hz drops it about 10 dB more, by about 600 Hz. When the drivers are summed, I guess this could cause a dip over that band, but I have no idea how audible or ‘unappealing’ that may be.
Before I fiddle around and try it, what do you think? Anyone done something similar?
Old 19th December 2004, 09:50 PM   #2
simon5 is offline simon5  Canada
I think that it won't be audible. Your PHL mid is not that good, 280 Hz is quite high!
I think the Peerless will be ok for what you need. Really good off-axis response.
DIYaudio for President !
Old 19th December 2004, 09:57 PM   #3
> Your PHL mid is not that good.
I understand why you think that. It’s very good at some things, but extension is not one of them.
I hope you’re right, but I’m asking not about off-axis response, but extended higher end response.
thanks
Old 20th December 2004, 12:05 AM   #4
Greg B is offline Greg B  United States
Geez, what a criteria to judge a driver by. If you want to cross lower than 300 you need a midbass not a midrange.
I guess this is philosophical: some prefer old skool 3 ways with a midrange covering perhaps 500-4k, while others prefer something more like a sub/sat configuration with the 'midrange' going down much lower into the midbass.
Considering the peerless driver in question, perhaps the latter approach makes more sense for this project.
GB
Old 20th December 2004, 03:37 AM   #5
You need good off-axis response if you want to use that driver to cover these frequencies IMHO, but it's not a problem since that driver does it well.
It will do well in extended higher end response if you use a 4th order crossover to prevent the dips and peaks.
Old 20th December 2004, 03:42 AM   #6
simon5
Encouraging - how high is the highest you've run it?
Old 20th December 2004, 03:42 AM   #7
Originally posted by Greg B Geez, what a criteria to judge a driver by. If you want to cross lower than 300 you need a midbass not a midrange.
Hehe, sorry maybe it was a bit harsh, but I prefer a midrange going down to about 50 Hz and up to maybe 2 kHz. A compression driver take care of 2 kHz and up. A real subwoofer take care of stuff below 50 Hz. It's still a 3-way design!
Old 20th December 2004, 03:48 AM   #8
Sorry rick57, as you saw in my first post, I don't own a Peerless XLS 12", but I would like to own one, really good driver!
I guess the 280 Hz you want to cross at is ok.
Old 20th December 2004, 05:33 AM   #9
Question high?
What’s the highest anyone’s used the XLS?
Anyone agree or disagree with simon?
What makes the JBL 2226H such a popular driver? Defo Multi-Way 13 11th November 2011 03:29 PM
Where am I crossed over dazed&confused Multi-Way 5 4th May 2009 02:46 AM
Enclosure for crossed over fostex AllenB Full Range 10 14th December 2008 01:35 AM
High Qms bass driver Ap Multi-Way 3 3rd June 2004 08:07 PM
Seas Excel W15 crossed over at 4 kHz - bad idea?? ThyroidAblation Multi-Way 3 21st January 2004 11:05 PM
Page generated in 0.11413 seconds (78.03% PHP - 21.97% MySQL) with 10 queries
