Can anyone out there help me with the Thiele/Small parameters for a Vifa 10 inch M26WO-06-04.I have just blown one of the subs in my Martin Logan SL3.I need the parameters to look for an alternative basselement because the original is rediculus expensive.
/ Sven-Åke |
#2 |
Best would be to measure the remainng woofer, then replace both with something that works.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 | |
/sven-åke |
#4 |
Another thing that i shuold mention,i had a 10-inch woofer MGR -20 -40 a really cheap woofer lying in the closet not even right impedance (6ohm) that i put in the hole in my SL3.I`m trying the balance right and left and can`t hear any difference in sound on the speakers,think it`s a little strange.Or is it so that it doesn`t matter on these low frequencies (250hz and down).Not even the crossover will work right with wrong impedance ,and still it sounds pretty good.
#5 | |
#6 |
Hi, Why don't you look up SOLEN's website. There you might find your particular Vifa driver.
http://www.solen.ca/ |
#7 | |
#8 |
Anyone by the way knows if the sensitivity on a loudspeaker is 89db does that mean all of the elements are 89db`s after the crossover?Before the crossover it can be more than 89db?
#9 | |
Perhaps, perhaps not. The Mfg spec of the finished speakers or individual woofers could be off by 3 or more dB depending on how they define it. That is why it is best to measure the original woofer parameters and match the DC impedance and derived (calculated) sensitivities of the originals to get the best match.
#10 |
I've seen listed something called a Vifa M26WR-19-04.
Are you certain that is not it?
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
| Anyone ever measured a Vifa C13WG-19-08's T/S parameters? | IG81 | Multi-Way | 0 | 28th April 2009 12:47 PM |
| Vifa P17SJ and Vifa D27TG Large Bookshelf MTM | rwo | Multi-Way | 7 | 24th February 2008 04:47 PM |
| Page generated in 0.15184 seconds (72.04% PHP - 27.96% MySQL) with 10 queries |
