Old 16th December 2004, 06:52 AM   #1
ERICSPEEd's Avatar
Default Help with finding good $40 7" mid-bass
Hello,
I'm planning on building a MTM TL using 7" mid-basses with Dynaudio D28/2 tweeters. I have the tweeters but haven't purchased the woofers yet. I was thinking of using one (I should say four) of these:
Peerless 832732 (Fs:34Hz, Qts:0.30, Vas:32.9l, Xmax:5.5mm, Sd:130cm^2) $33.50
Peerless 850122 (Fs:37Hz, Qts:0.44, Vas:27.7l, Xmax:5.5mm, Sd:143cm^2) $39.30
I'm looking for 7" woofers with an Fs of 30 ~ 35Hz (I know the 850122 is 37Hz) and I can't spend more than $40.00 per woofer.
Any recommendations would be of great help and I would seriously look into any suggested woofer.
Thanks in advance!
Eric
I thought a signature was an abstract form of cursive?
Old 16th December 2004, 11:25 AM   #2
ERICSPEEd's Avatar
Default I don't use cookies!!!!!!!!!
Sometimes when i try to post I lose my posting due to the login situation, makes me mad.
Ok...
I think I would be better off uping the dollar amount to around $60 per woofer.
I'm interested in these:
Vifa XG18WHOO-08
Seas G18RNX/P .phf info available in the Seas vintage section, but Madisound still has them (at least for the moment). Seas has a replacement driver: G17REX/P.
Any comment on either of these? I plan to use them in a MTM TL.
Thanks!
Old 16th December 2004, 12:06 PM   #3
Banned
You'll get the lowest extension from the Peerless 850122 , but before going any further you also need to consider the crossover point. Make sure that the driver you choose is no more than 6dB down at 30 degrees off axis at the crossover point for proper imaging.
Old 16th December 2004, 12:17 PM   #4
ERICSPEEd's Avatar
Thanks Bill (I should send you a Christmas Card or somethin').
That would save me some money. If you don't mind my asking, what is your rational for the Peerless driver, experience with it or based on the T/S specs?
The two Peerless were my first choice, well 1st/2nd or 2nd/1st choice (if you get me).
I plan to cross the dyn around 2k give or take.
Old 16th December 2004, 01:13 PM   #5
gary f is offline gary f  Canada
gary f's Avatar
There is always the classic Vifa P17WJ-00 which is nice sounding, and an overall good performer. Also, there is loads of design using it...
Peerless HDS seems like a very nice choice.
Old 16th December 2004, 04:43 PM   #6
bwbass is offline bwbass  United States
Haven't used it, but there's always the PE Euro 7" @ $35:
http://www.partsexpress.com/pe/pshow...number=295-350
Edit: Oops! I see the Fs is 40Hz. Otherwise looks like a nice driver.
Old 16th December 2004, 05:01 PM   #7
Default PE RS180
You might wish to consider the PE RS180:
http://www.partsexpress.com/pe/pshow...number=295-364
It has an Fs of 38 Hz, so that's a bit higher than you'd like, but it has been getting a lot of positive attention. Price is $30.74 each for 4 or more.
I haven't used it, personally, but if you do searches here and on the Madisound board, you'll find out quite a bit about it.
Good luck.
Paul Ebert
Old 16th December 2004, 05:10 PM   #8
Timn8ter's Avatar
A fellow Washingtonian recently used the Euro in a small PR cab and it produced a very satisfactory amount of bass. One of the best builds he has done to date. I believe he used a PE tweeter also but I don't remember the model, sorry.
Old 16th December 2004, 05:17 PM   #9
On second thought, the Euro's .29 Qts is a bit low for a TL - I second the PE RS 7" as a good TL candidate. Looks cooler, too!
Old 16th December 2004, 05:32 PM   #10
With the RS180, do keep in mind that it has a significant (to say the least) cone breakup due to its aluminum cone. But, if you can design a good crossover for it, it should be a good choice.
Need some help with finding a really good headunit Flyin11 Car Audio 26 12th December 2007 02:54 AM
Looking for a good 6.5" mid bass cody6766 Multi-Way 4 30th September 2004 01:06 AM
help finding a good amp project? confused Tubes / Valves 6 19th April 2004 07:04 PM
Page generated in 0.11008 seconds (72.91% PHP - 27.09% MySQL) with 11 queries
